> flywheels, lightweight and step
post May 13, 2005 - 10:43 AM
ok what would be the ideal weight if i'm goin to machine a flywheel for the 7afe
and
what does
"step +.018" mean?
post May 13, 2005 - 12:02 PM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
It might mean something along the lines that its a stepped flywheel? Iono just my guess, and i dont know $hit
AIM : FAQdaWorld
post May 13, 2005 - 12:06 PM
well i need a fact not a guess b4 i order
post May 16, 2005 - 1:42 PM
bump cause sumbody has to know this
and does anyone know stock flywheel weight?
post May 17, 2005 - 8:40 AM
CelicaST18
Joined Sep 1, '04
From Ohio
Stock 7afe flywheel weighs 19 lbs...i have a 9 lb aluminum clutchmasters flywheel
Flywheel
post May 17, 2005 - 2:40 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
I would be extremely careful machining down an OEM flywheel. They have a tendancy to break up at high rpm causing serious damage.
Much better to get a custom made one IMHO.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post May 17, 2005 - 3:07 PM
high rmp?
my st doesn't even hit 6k lol
post May 17, 2005 - 3:15 PM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(playr158 @ May 17, 2005 - 3:07 PM)
[right][snapback]288123[/snapback][/right]
That's still a ****load of angular momentum. Trust me, you do not want a flywheel disintergrating at speed. It's like a frag grenade.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post May 17, 2005 - 9:06 PM
slipgun
Joined Jun 2, '03
From Annandale VA
how much was your lightend flywheel?
post May 18, 2005 - 1:43 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
how much does a lightened flywheel help with acceleration/hp/reving? And how much does installation cost? I assume that most people couldn't DIY?
post May 18, 2005 - 2:34 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(CheesyLobster @ May 18, 2005 - 6:43 AM)
[right][snapback]288383[/snapback][/right]
A light flywheel will noticeably improve engine responsiveness, essentially increasing acceleration speed. Its effects are something like static weight loss... It doesn't really *add* hp or anything like that. Also, I wouldn't get a 2 piece like most of the Fidanza/Clutchmaster flywheels. 2 piece flywheels can wear and fall apart under stress. My cousin blew one up in his Civic a couple years back, successfully destroying his tranny and engine. Just IMO...
As for install... expect it to cost as much as a clutch install. The work is basically the same.
post May 18, 2005 - 8:41 AM
CelicaST18
Joined Sep 1, '04
From Ohio
i imagine a one peice wouldn't be as light as a two peice because there has to be a steel friction surface...if the flywheel is made of aluminum, the second peice would have to be a steel surface bolted to it. I installed mine myself..but, i had access to a lift, it would be harder on jackstands, but still do-able. Installation is exactly like a clutch with the addition of taking off the flywheel (eight bolts on a gt, six on an ST) and putting on the new one...io would suggest raplacing the clutch if you are close to neediing a new one so you don't have to do it twice/ pay for it twice.
Parts database
post May 18, 2005 - 3:03 PM
GT4WRC
Joined Mar 17, '05
I've just bought one of these -
Chrome-Moly Flywheel weighing approximately 4.2kg. That's 300g lighter than the equivalent two piece wheel that you can get. It's also lighter than the clutch plate and cover combined too!
Picking it up when I'm over in Oz next week.
It's from here - http://www.xtremeclutch.com.au/products.htm#
Gary
GT-Four spec list
post May 18, 2005 - 3:45 PM
ok so so 7afe lightweights are limited to findeza or clutchmasters
but 400$ for a flywheel is gay
so if i do machine my stock one i'm not lookin to go crazy amount shaved off....
if the stock weight is like 20
would 10-12lbs be ok?
or depends on machine shop?
post May 18, 2005 - 3:52 PM
GT4WRC
Joined Mar 17, '05
QUOTE(playr158 @ May 18, 2005 - 3:45 PM)
[right][snapback]288654[/snapback][/right]
$400 is gay? Wonder how much it'll cost to repair a car whose flywheel has broken up at high rpm. rolleyes.gif
Don't take this the wrong way, but you've come here asking for advice and it's been given. Do it properly. Buy a custom made wheel. Far too many risks assosciated with maching a flywheel down. Especially if you want to halve its weight!
Gary
GT-Four spec list
post May 18, 2005 - 4:16 PM
400$ for a what it does isn't an idea at the moment
i should have stated until i do my motor rebuild and have my setup
custom made? as in clutch masters? cause thats not really custom
basically i just want to shave sum off even a 15lbs would be fine
cause i'm not goin to be running this motor very long
i'm goin to be starting my new motor project with a much better build then the crap tastic one in the car now
Lo-Fi Version Time is now: January 10th, 2025 - 11:48 AM
