FS: Driver's Side Tail Light and Power Antenna |
May 15, 2005 - 4:16 AM |
Enthusiast Joined Mar 19, '05 Currently Offline Reputation: 0 (0%) |
May 15, 2005 - 6:02 AM |
does the antenna work?
May 19, 2005 - 1:25 AM |
Oh, yes, absolutely. It was working perfectly fine when removed. Sorry, I forgot to mention something so important.
May 19, 2005 - 9:49 AM |
Enthusiast Joined May 17, '03 From Florence, KY Currently Offline Reputation: 0 (0%) |
Is it the stock power antenna? I need one to fit my coupe. I also need the exterior antenna mount if you've got one.
This post has been edited by BlackSTX: May 19, 2005 - 9:50 AM |
May 19, 2005 - 11:08 PM |
Yes, it is the stock hatchback power antenna with everything you see in the picture. The antenna mast, motor, relay, bracket, rubber grommet and nut are all included.
Basically, to swap out yours with this one: -remove the nut around the mast -remove the nut on the bracket -disconnect the antenna connector -disconnect the relay connector -remove old antenna -put in new antenna -connect the relay connector -connect the antenna connector -put on the nut on the bracket -put on the nut around the mast and it should work fine assuming everything else on the car is working the way it should. * BlackSTX: I am not sure if the hatchback antenna is different from the coupe antenna. Does anyone know this? |
May 23, 2005 - 1:25 AM |
Enthusiast Joined May 14, '05 Currently Offline Reputation: 0 (0%) |
I NEED THAT TAIL LIGHT!!!!! I PMed you. If it's easier- travelchute@yahoo.com
pretty please sell it to me!? how much? |
May 23, 2005 - 11:38 AM |
Enthusiast Joined Nov 20, '02 Currently Offline Reputation: 1 (100%) |
You have PM!
Lo-Fi Version | Time is now: November 28th, 2024 - 8:16 PM |
