> Fog Light electrical?, Probably been asked before...
post Apr 15, 2003 - 8:45 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
I'm sure someones already asked before, but I'm trying to install KC fog lamps, and I need help with the electrical. I have the mountings all made, but I don't know where to tie the lights into the electrical system, and how to get a switch in also. I've got a 94 GT hatchback, if that makes any difference. I'm a newbie for electrical, so as specific as you could get would be great. I had the bottom of the dash off, but there is such a mess of wires, i couldn't find the fog light fuse that the manual says I have. Any help?
Alden
psalm 69
post Apr 15, 2003 - 10:32 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
YOu dont ahve to tap in your should wire them up and run the hot to the battery and ground the black and all it should have a diagram to show you unless your wanting them to come on with your lights and then you could wire it to the dimmer!
99 Toyota Tacoma
post Apr 16, 2003 - 12:46 AM
Guest_Matthew_*
yea or wire the hot to the panel fuse...that way when you turn on your lights then your fog lights will come on too.
post Apr 16, 2003 - 11:05 PM
FallenHero
Joined Dec 26, '02
From Alabama
The power comes on to the fuse panel whenever the car starts. Or that's how it is on my car. Sorta like fuses in your house. If you wire your ground to the ground on one of your fog lights it might work though.
Lo-Fi Version Time is now: December 1st, 2024 - 6:16 AM
