![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) ![]() |
When I start my Celi after it has been cold for awhile (as short as 2 hours) it wont idle high enough to stay on! the rpm's just drop till it dies, I either have to give it gas to idle it, or rev it up and the self idle finally kicks on! I know reving a cold engine is terrible for any car! anything would help.
i doubt that it gets cold enough in LA in april to hurt the engine. get a tune up. check plugs, wires, etc.
oh and make sure that there is enough gas in the car. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) ![]() |
check your fuel injectors they might be clogged
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) ![]() |
Once someone couldn't get their car to start @ DSMTuners.com to start and i was like "you check your plugs wires gas etc?" and he was like yeah it's all fine..and he's like "it just wont turn over" i was like "well did you push the clutch in" ..and he posted the next day... "hey it's working now"..
![]() Enthusiast ![]() Joined Jan 20, '03 From Denver, co Currently Offline Reputation: 0 (0%) ![]() |
This is a possibility, you should get a fuel tune up. another possibility is the fuel filter is clogged. |
so a tune up? and yes I do know about the clutch... the car will turn on but then the rpm's drop... how much is a fuel injection cleaning? and a tune up? and is a dealer the best place to go for the tuneup?
![]() Enthusiast ![]() Joined Nov 15, '02 From california Currently Offline Reputation: 0 (0%) ![]() |
The exact thing happened to me. In a span of two months, my celi started then just died three times. I was due for my 60,000 so I did the regular maintenance (new plugs, topped fluids, flushed coolant, changed oil & filter . .. ). I told them about it and they couldn't figured it out. They did notice my battery was a four or five year old battery and may be near the end of its life. They say that was it and replaced it , but I don't believe them. The month after all that work done, my car did the same thing. I started it and it died two seconds later. I had to press the gas for twenty seconds, then it was fine.
It hasn't happened since, its been two months. If you find out what's causing this, let me know. |
I'm most likely going to the dealer for a tune up within the month. I'll inquire about it then. And this dosnt happen off and on, it happens pretty much every time...
![]() Enthusiast ![]() ![]() ![]() Joined Mar 9, '03 From Orting, WA Currently Offline Reputation: 0 (0%) ![]() |
Man i didnt know this topic was here. I just posted a topic ascking the same thing. This just started to happen to my car too. 75000 miles. I replaced the battery, spark plugs, and wires, cleanned the fuel system, all today and it is still happening. Heres the thing, when the engine is cold it starts fine, When it is still really hot it starts fine, but when it cools down for like 2-3 hours its doing the dieing thing. I dont get it. No one knows what the problem is becasue when they go to look at it, it doesnt happen. Including the dealership, dont go there. They r crooks. Im thinking it might be a fuel filter or something in those lines. I hope someone fines this problem and what it is....
tell me about it. the toyota dealership garage mechanic was useless. "well, I can't tell you what causes it " he said. I left the car with him for the day to do that 60,000 maintenance. he said, " well it didn't happen while I had it the whole day, so . . ." he was not very much help.
let me know if anyone finds out anything. |
every time I try to show it to someone it starts wonderfully! absolutly perfect! only person that has ever seen it is my girlfriend, and she dosnt even know which side the gas is on... :-/
DOes anyone think the problem might be in with the Cooling system somehow? I live in NC and it only started happening when the weather was warming up to the high 70s and 80s. If not that could it be a default in the ECU or something.
Did anyone fix the problem.. I did, it was the COOLING SYSTEM...Problems all gone now....
what did you do to the cooling system?
To easy. All I did was flush out the radiator system, refill and also made sure i filled the white plastic reserve tank. All of a sudden the problem is gone, hasnt given me **** in weeks.
so you did a coolant flush yourself? the dealer wants $100. I havnt checked anywhere else yet |
dude
dont go to the dealer/ have a neighbor or a local normal shop do it if you cant. seriously when it comes to something like that...pretty much any shop can do it. but its your money |
yeh I know not to go to the dealer, its just the only place I have goten a price from... |
Lo-Fi Version | Time is now: February 23rd, 2025 - 3:58 PM |
