![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
post the the sheets and a list of mods
i know itchy ,me , jgreeny have dyno sheets so what do you think coomer should we make a sticky just info no chatting we have a 7afte, 5sfte, 7agte (soon) , swaped 3sgte oh and mina_xxx too even throw in some of the gt4 guys in there -------------------- yea your 3sgte is cool but ill stick to my 7agte
What if you wanna talk about the Dyno sheets? No chatting isnt a very good option in a discussion forum.
QUOTE(Supersprynt @ May 19, 2005 - 9:21 AM) What if you wanna talk about the Dyno sheets? No chatting isnt a very good option in a discussion forum. [right][snapback]288961[/snapback][/right] then start a topic in that forum instead of cluttering up the sticky like 5sfte dyno results but just have sheets and mods in the stick and just hyper link the chatting post to it FOE EXAMPLE 7AFTE ![]() ![]() ![]() ![]() list of mods ngk spark plugs custom 2.25 exhaust with a ractive muffler garret t3 turbo jgstool manifold F-tuning feed line vortech fmu 12:1 ractive filter jgstool drain line kit custom DP w/ heat wrap walbro 255 lph fuel pump greddy type S bov custom 52mm intercooler piping JohnnyRaceCar intercooler ASP underdrive pulley greddy Profec E-01 then add a link for 7afte dyno chat go here http://www.6gc.net/forums/index.php?showto...2&hl=7afte+dyno This post has been edited by nik: May 19, 2005 - 2:40 PM -------------------- yea your 3sgte is cool but ill stick to my 7agte
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) ![]() |
I personally feel my engine tech should be stickied aldo.
![]() http://www.6gc.net/forums/index.php?showtopic=24821 You know... just a suggestion. ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) ![]() |
^^ i think it should be stickied...
![]() Enthusiast ![]() ![]() Joined Jan 28, '05 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) ![]() |
Ill third it
-------------------- Speeding is only Illegal...
If you Get Caught |
Sry for hyjacking...
Ok, Engine and tranny sticky setup needs to go in favor of a more organized setup. I don't know if it can be done... But I LOVE the way club4ag did their tech section... as in http://www.club4ag.com/technical_main.htm However, cluttering up the eng\tran section with ten stickeys is not the option either. We need a swap/turbo sticky, a tech sticky-> what it is, how to mod it (linking to the swap/turbo sticky when needed) This would include links to the discussion and mod lists/dyno sheets, wiring info, etc, etc. And then a Faq: This would be anything else needed to tidy up loose ends. Bam, three faq's that run the gambit. If they are arranged correctly, it'd be very understandable and easy to use. |
dag gone it
i fourth that engine spec sticky like i've been for the last 2 weeks |
QUOTE(FallenHero @ May 25, 2005 - 8:57 PM) Sry for hyjacking... Ok, Engine and tranny sticky setup needs to go in favor of a more organized setup. I don't know if it can be done... But I LOVE the way club4ag did their tech section... as in http://www.club4ag.com/technical_main.htm However, cluttering up the eng\tran section with ten stickeys is not the option either. We need a swap/turbo sticky, a tech sticky-> what it is, how to mod it (linking to the swap/turbo sticky when needed) This would include links to the discussion and mod lists/dyno sheets, wiring info, etc, etc. And then a Faq: This would be anything else needed to tidy up loose ends. Bam, three faq's that run the gambit. If they are arranged correctly, it'd be very understandable and easy to use. [right][snapback]291901[/snapback][/right] good idea less cluter ![]() -------------------- yea your 3sgte is cool but ill stick to my 7agte
Lo-Fi Version | Time is now: February 23rd, 2025 - 1:48 PM |
