> fuse for window, pass. side
post May 19, 2005 - 6:30 PM
95gtschick
Joined Sep 18, '04
From Manitoba, Canada
where is it? i've asked before and no one answered, i need to know asap that's why i made i a new thread. thanks
post May 19, 2005 - 7:05 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
check under your steering wheel, just t o the left there is a panel, pull it off and look on the back of it, it will give you a list of all the fuses and what they are for. If its not there, do the same thing but in the engine. If your facing your car from the front, it will be on the right side in a big black plastic box.
To live, is to suffer
post May 19, 2005 - 8:00 PM
95gtschick
Joined Sep 18, '04
lol sorry for not specifying, but i've looked in both relay boxes under the hood, and in the fuse box in the car. (i'm not an idiot smile.gif) hehe. i'm just saying that it's not in any of those places.... thanks anyway
post May 19, 2005 - 9:28 PM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
why do you need to find it? if it's because your window doesn't work, then id turn the car off, but have the key in the "on" position and press the window button. if you can hear the motor try to work, but nothing is happening, then the tracks or something else is binding. if you dont hear anything, then check all the wiring and look for a blown fuse biggrin.gif.
post May 19, 2005 - 11:14 PM
95gtschick
Joined Sep 18, '04
sigh! check for a blown fuse... sorry, but that's what i'm asking. where is it?
post May 21, 2005 - 3:21 AM
rocky2006
Joined Aug 18, '04
not sure, but just check every fuse you can find in the engine bay and under the dash to see if any are blown. should take like 5 mins.
This post has been edited by rocky2006: May 21, 2005 - 3:22 AM
post May 21, 2005 - 9:02 AM
95gtschick
Joined Sep 18, '04
i did, but here's the problem, none of them are for the window, and none of them are blown. here's the real issue. we tested the connector coming from the motor, and the connector coming from the switch. Both have power, both work, but as soon as you connect them, they don't work. We're very confused as to why this would be, that's why we're thinking fuse maybe? we have no idea
post May 21, 2005 - 1:30 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
maybe its grounding out somewhere? And just to be 100% you went through each and every fuse to make sure they are all good right?
Lo-Fi Version Time is now: February 23rd, 2025 - 1:05 PM
