> gas, horrible gas mileage
post May 20, 2005 - 9:00 AM
95gtschick
Joined Sep 18, '04
From Manitoba, Canada
okay i've replaced my fuel filter, it didn't help a whole lot. the most miles i've EVER gotten on a tank is like, 280, if even.. that's REALLY pushing it. what else can i do? i've heard spark plugs/wires... what else?
post May 20, 2005 - 9:28 AM
red94celicagt
Joined Jan 28, '05
From Cincinnati, Ohio
I have similar problems...I get about 320 maximum (with a 15.9 GAL tank that's only about 20 MPG)
Have you gotten your oil replaced regularly?
Maybe your car is not aligned...this contributes to a few MPG of fuel loss
Are you driving with your foot to the floor all the time?
All of these thigns, plus more, contribute to less gas milage.
I was getting about the same milage as yours...about 280 to the tank...and I found out my car was way out of align...I got it realigned and now I gained about 50 miles on the tank. I also drive very aggressively, however, which would be a big reason that my MPG suffers
Im say take it to a mechanic you trust (that won't charge you to take a quick look) and ask him why your MPG are so low...he probably can do a diagnostic and figure out at least a few reasons...
Speeding is only Illegal...
If you Get Caught
post May 20, 2005 - 9:49 AM
95gtschick
Joined Sep 18, '04
i never drive aggressively, i drive really... really nicely. never put my foot to the floor
post May 20, 2005 - 9:54 AM
red94celicagt
Joined Jan 28, '05
hmmm, well in that case I'd say check your alignment
When you elt go of the wheel does your car start trailing left or right?
Check your tires also for uneven wear or a worn belt in the tire...
If you Get Caught
post May 20, 2005 - 10:10 AM
celicaboston1983
Joined Mar 20, '04
the condition of the tires effect mpg?
post May 20, 2005 - 2:25 PM
Skate4mindgame
Joined Oct 1, '04
From Michigan
Yes it can just as can having underinlflated tires.
post May 20, 2005 - 2:31 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
i only get 20-24...i maintain regularly, cant get 30!
got aligned, new tires, new this, new that.
post May 20, 2005 - 2:44 PM
95gtschick
Joined Sep 18, '04
my highest mpg is like, 17. i do oil changes and all that very regularly, alignment on the car is awesome, i have new tires..., etc
post May 20, 2005 - 2:51 PM
Skate4mindgame
Joined Oct 1, '04
From Michigan
A tune up helps really nicely most of the time if you are getting horrible gas mileage i know my car was only running on 3 cylinders when i first got it =X
post May 20, 2005 - 4:05 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
Tune up = new rotor, distributor cap, spark plug wires, spark plugs, air filter, and adjust timing. I get around 400 miles to a tank. Also, make sure your tires are properly inflated. If they aren't, then you'll lose some miles.
post May 20, 2005 - 5:10 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Make sure its not running lean.. I get around 25-28 mpg.. depending on how i drive.
post May 20, 2005 - 11:43 PM
exxtractor
Joined Mar 31, '03
From BC
Check your O2 sensors. I had one not working properly and wqas getting terrible fuel mileage (read old posts), changed one of the O2 sensors and everyhting s back to around 28 MPG (mixed driivng + agressive)
post May 21, 2005 - 2:03 AM
QUOTE(exxtractor @ May 20, 2005 - 11:43 PM)
[right][snapback]289823[/snapback][/right]
100% correct. O2 sensor failure are common in Toyotas. There are 2 to check/replace.
for better info, do a search for "sensor" or "mileage" I'm sure you will find a lot of posts and info about this.
Lo-Fi Version Time is now: November 27th, 2024 - 6:00 AM
