my 3sgte motor has just been lying there, for about 1 year now, what should I do? |
May 20, 2005 - 12:21 PM |
Enthusiast Joined Sep 24, '02 From North Carolina Currently Offline Reputation: 1 (100%) |
Hey guys,
my ST185 3sgte motor has been lying in my garage for about a year now because I never had time to swap it. Its in a shop right now about to be start up and have a compression test done to it. I was just wondering what do you think could be a common problem with an engine lying there for so long??? Please let me know, thanx in advance. -------------------- |
May 20, 2005 - 12:23 PM |
Rust, corrosion...most all swapped engines are sitting for a long time before their put in.
May 20, 2005 - 1:03 PM |
ill tell you something i learned with my motor. replace every gasket you can think of, because they will all leak. do the valve cover gasket, rear main seal, distributor gasket, thermostat, waterpump, timing, belt, idler pulley and tensioner, and everything else you can think of.
This post has been edited by lagos: May 20, 2005 - 1:04 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 20, 2005 - 1:08 PM |
advanced auto parts
sells full engine gasket kits investing in that as per lagos' suggestion would be good |
May 20, 2005 - 3:12 PM |
Enthusiast Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
You should tell them that how long it's been sitting. When a motor sits that long, you should put lube in each cyl a day before you are about to start the motor. It's prolly been sitting another year before you got the motor too. I think the lube everyone uses is called marvel mystery oil. It's a penetrating lube for the rings.
May 20, 2005 - 3:17 PM |
yeah...i hear a drop of motor oil through the sparkplug holes does the same thing.
May 20, 2005 - 3:22 PM |
Coolant flush. Mine was nasty.
Lo-Fi Version | Time is now: December 4th, 2024 - 9:31 PM |
