High RPM on 5th Gear |
May 20, 2005 - 9:23 PM |
Enthusiast Joined May 20, '05 From San Diego, California Currently Offline Reputation: 0 (0%) |
I'm pretty much new to driving stick (learned a week ago), but something seems wrong when I'm crusing on the freeway on 5th gear. Is it normal for me to be getting around 3,000-3,200 RPM going around 60-65 mph? It just seems a little high compared to my now-scrapped automatic eclipse which got around mid 2,000's at those speeds.
May 20, 2005 - 10:13 PM |
Enthusiast Joined Jul 11, '03 From Kennesaw, Ga Currently Offline Reputation: 0 (0%) |
Don't know about the GT, but it's the same way for my ST.
Now I'm loving my new 6 speed RSX-S Still around 3K rpm around 60 mph...but I've got a higher redline now |
May 20, 2005 - 10:19 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Its just that way celicas are. I never need to touch 4k in my civic.
DEF -------------------- I will return one day. |
May 20, 2005 - 11:56 PM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
For me, 3700~ doing 80MPH.
May 21, 2005 - 3:17 AM |
Enthusiast Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) |
hmm, 80 mph on my auto ST is like 3200 rpm.
May 21, 2005 - 5:32 AM |
GT for me = 4k is 80mph. i think 3k is 60 ish i dont do 60... ish often... so i dont know
May 21, 2005 - 11:38 AM |
Well the thing is, usually autos have a lower RPM for higher speeds compared to stick, and since I have to drive on the freeway a lot, I'm worried that consistent 3k+ RPM will reduce gas mileage and/or cause increased engine wear.
May 21, 2005 - 3:16 PM |
Enthusiast Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
I wouldnt worry about it, i get 28mpg on highway trips going 90 or above.
May 22, 2005 - 12:29 AM |
Enthusiast Joined Jan 28, '05 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
manual trannys are made to handle 3k RPM at 65 MPH just as auto trannys are programmed to go about 2,4k RPM at 60...
Your car will be fine...gas milage will be same if not better than auto...you will not burn out engine internals or tranny... Basically...keep the RPMs out of th redline range...your car will be fine as it was made to operate safely and reliably at any RPM up to about 6k -------------------- Speeding is only Illegal...
If you Get Caught |
May 26, 2005 - 12:14 AM |
Enthusiast Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) |
hahaha they wont go to the redline range stupid fuel shutoff
May 26, 2005 - 1:34 AM |
wow i'm still in 4th grear when doing 60 ... us ally don't shift into 6th till i hit about 75- 80mph ... but i drive every agressive ... in the city i never get out of 3rd grear...
May 26, 2005 - 8:15 AM |
QUOTE(macavely @ May 26, 2005 - 1:34 AM) wow i'm still in 4th grear when doing 60 ... us ally don't shift into 6th till i hit about 75- 80mph ... but i drive every agressive ... in the city i never get out of 3rd grear... [right][snapback]291952[/snapback][/right] well yea...in fourth you could actually get up to about 100 in fourth...it says the max speed per gear in the owner's manual and I believe the highest in fourth is about 100. thats relining it, tho...probably even going into redline a bit (6,5 or 7k) -------------------- Speeding is only Illegal...
If you Get Caught |
May 26, 2005 - 8:37 AM |
MAC since when do we have 6 gears?!
May 27, 2005 - 5:06 PM |
Enthusiast Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
hmm i think it's normal for the celi to reach 3000+ rpm when at 60.. lol... but i'm not like mac.. when i'm on local.. i shift at low rpms so to prevent my muffler from being to loud. when i'm at highways i normally shift at around 4000rpm.
May 28, 2005 - 6:53 PM |
80 MPH for me is around 4,300 - 4,400 RPM. The AE101 C-52 has shorter gears than the AT200 C-52.
Sep 21, 2005 - 11:19 PM |
Enthusiast Joined Aug 31, '02 From Virginia Currently Offline Reputation: 4 (100%) |
Well, now that I currently own both an Auto and Manual 1995 GT Celicas, here are my observations:
GT Auto at 80 mph ~ 3,100 RPM GT Manual at 80 mph - almost 4,000 RPM So, there is nothing to worry about here with the manaul? Someone explain this. Thanks. |
Sep 22, 2005 - 2:29 AM |
Enthusiast Joined Feb 7, '05 From Fresno, CA Currently Offline Reputation: 0 (0%) |
QUOTE(MonsterBOX @ May 26, 2005 - 12:14 AM) hahaha they wont go to the redline range stupid fuel shutoff [right][snapback]291932[/snapback][/right] The redline starts at 6200 and my fuel cutoff is at 6500-6800 somewhere around there its been awhile since I tested it out. |
Sep 22, 2005 - 12:02 PM |
QUOTE(Celicav @ Sep 21, 2005 - 11:19 PM) Well, now that I currently own both an Auto and Manual 1995 GT Celicas, here are my observations: GT Auto at 80 mph ~ 3,100 RPM GT Manual at 80 mph - almost 4,000 RPM So, there is nothing to worry about here with the manaul? Someone explain this. Thanks. [right][snapback]337187[/snapback][/right] no thats normal. manuals and autos are geared differently. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Sep 23, 2005 - 11:31 AM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
QUOTE(Celicav @ Sep 21, 2005 - 11:19 PM) Well, now that I currently own both an Auto and Manual 1995 GT Celicas, here are my observations: GT Auto at 80 mph ~ 3,100 RPM GT Manual at 80 mph - almost 4,000 RPM So, there is nothing to worry about here with the manaul? Someone explain this. Thanks. [right][snapback]337187[/snapback][/right] yeah, definitely nothing to worry about. The auto and manual are geared differently because the auto is technically only a 4 speed. -------------------- 1999 Celica GT
Sep 24, 2005 - 2:39 AM |
Enthusiast Joined Mar 17, '05 From Northridge, CA Currently Offline Reputation: 0 (0%) |
if you want to get the most performance, shift around 5,300~5,400 rpm as the high rpms don't provide as much power. my 94' GT is my first stick as well... and learning to drive stick on it has been a dream. You'll stall a few times, but you'll get the hang of it after a week or so.
And don't worry about the high end... i mean there is no point in going very high as it doesn't provide as much power as the power band (4k-5.3k), but i've had my car at 6.8k for a few sec and it was just fine. |
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:57 AM |
