> Gurggling sound?, help
post May 20, 2005 - 10:58 PM
kalark
Joined Apr 15, '05
From Bend ORegon
Okay, So I had a shop fix a few shorts today. When I got it back It had this like gurgling sound coming from around the throttle body...
Like it's only when I push the accelerator like 1/2 of the way down, like a little bit more and it stops. So what do you think it could be?
post May 21, 2005 - 3:18 AM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
i dont know, but i have this sound too. help would be nice.
post May 21, 2005 - 12:03 PM
drdos
Joined Aug 19, '03
From Buffalo,NY
sounds like it could be a overheating problem. Check ur water pump and make sure its pumping water. also Check the head gasket . i had that same problem it turned out to be a head gasket, but the time i found out i warped the head. so be carefull.
post May 21, 2005 - 6:30 PM
kalark
Joined Apr 15, '05
From Bend ORegon
well. I don't think it's over heating. Cause the temp gauge stays normal. But it could be reading wrong.
And what was wrong with the head gasket?
Me and a freind recently replaced mine (swapped the heads. wasnt blown gasket or anything)
post May 25, 2005 - 11:06 PM
rocky2006
Joined Aug 18, '04
could it be an overheating problem if our oil temp gauges are at normal temperature?
post May 26, 2005 - 2:04 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
bring it back
Lo-Fi Version Time is now: December 1st, 2024 - 5:36 AM
