> Wiring something to my exhaust
post May 20, 2005 - 11:13 PM
Mike
Joined Oct 22, '02
From Toronto
I was wondering if anyone could give me some advice as to the best place to drill a hole to get a wire from my exhaust cutout which is right behind my header, up though the car and to my center console confused.gif
post May 20, 2005 - 11:51 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
What exactly are you trying to do?
post May 21, 2005 - 12:37 AM
Mike
Joined Oct 22, '02
From Toronto
I have an electronic exhaust cutout system and the switch for it needs to be wired up throught the bottom of the car and to the center console so i can turn it on and off from inside the car
post May 21, 2005 - 1:29 AM
Hanyo
Joined Aug 16, '03
From Bay area
i would run the wire up into the engine bay and through a hole in the fire wall.
or maybe through the rubber boot the engine harness uses..
try to keep the hole far away from the cut out so the exhaust fumes have a harder time to get into the cab.
post May 21, 2005 - 7:11 PM
Mike
Joined Oct 22, '02
From Toronto
QUOTE(Hanyo @ May 20, 2005 - 11:29 PM)
[right][snapback]289871[/snapback][/right]
good idea
i'll try and wire it up through the enginebay and thru the firewall
Lo-Fi Version Time is now: February 23rd, 2025 - 3:48 PM
