> Scotch Tape, AAAAAAAAAAA
post May 23, 2005 - 4:31 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
I was painting my calipers and I was covering my car with newspaper and scotch tape. When I finished, I noticed that the scotch tape left adhesive marks on the car. How do I remove this? It's sticky, like when you peel off a sticker. I want to remove this without removing the paint. Lol. Help a.s.a.p. Thanks!
post May 23, 2005 - 4:39 PM
macavely
Joined Nov 4, '02
use rubbing alcohol... then wipe off with water..
post May 23, 2005 - 4:44 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
and next time use painters tape or even masking tape.
Team 6gc 2005
post May 23, 2005 - 4:50 PM
RedSunCelica
From San Diego CA
go to walmart or a automotive store and buy a thing called "goo gone" works wonders.
post May 23, 2005 - 4:52 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
so goo gone and rubbing alcohol will work fine and not remove any paint? what's the better bet?
post May 23, 2005 - 4:55 PM
RedSunCelica
From San Diego CA
^^ when i removed my stock emblems the adhesive was left behind. i used goo gone and it removed the adhesive and did not damage the paint. i also used it to remove vynal adhesive left behind.
post May 23, 2005 - 9:10 PM
jgreening
Joined Jan 17, '04
From Illinois
Any mild detergent will work fine - this is scotch tape afterall. I would be careful about alcohol or turpentine type compounds if you stuck any to painted areas.
post May 23, 2005 - 9:43 PM
red94celicagt
Joined Jan 28, '05
From Cincinnati, Ohio
Goo gone is made for this problem...it isn't called "everything gone" and therefore won't take off your paint...do not use nail polish, lol.
Speeding is only Illegal...
If you Get Caught
post May 24, 2005 - 12:25 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
Well I tried to remove some scotch tape adhesive from my car using alcohol and it scratched the car up for some reason. i used a soft towel and I rubbed it softly. I don't know why. But i bought this scratch remover thing from an auto parts store nearby. I wanted to know if anyone's used this before and if it'll work. Thanks.
Lo-Fi Version Time is now: December 12th, 2024 - 10:19 AM
