Tein S-Tech Springs, Need Camber Kits? |
May 24, 2005 - 3:15 PM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
After I lowered the car with the S-Tech springs (0.9in front, 1.4in rear). The camber's totally off. The car's running like this:
/ \ (well not that extreme but u get the point...) I went to an alignment place to get a quote, and he said I'll need an camber kit to make the wheel perfectly straight (0 degree camber) Do I really? -------------------- |
May 24, 2005 - 3:39 PM |
no, not unless you got coilovers.
Coilovers = camber kit and alignment no coilovers = no need just allignment -------------------- |
May 24, 2005 - 3:45 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
dont are cars come camber adjustable from the factory?
May 24, 2005 - 4:14 PM |
hey tomaz, i can give u the number to a goodyear place and maybe get you a deal...(562) 430-7559, ask for chris and tell him jeff sent you...they do good work, good hours, and dont try to bs you on anything. they located in los alamitos, just off the 605N, take katella and right on los alamitos, few stores down on the right. i think they charged me 100 bucks to do it and if it feels off, take it back and they will do it for free.
May 24, 2005 - 5:00 PM |
4 wheel alignments should run 60$ at most....Keep shopping around. Maybe Cali charges alot more though You dont need a camber kit for tein s-tech's....shoot, they bearly need to adjust for them anyways. I have the before and after spec sheet and it was very slightly off
May 24, 2005 - 5:20 PM |
o ya i think it was $60, wasnt sure. could check a receipt.
May 24, 2005 - 5:39 PM |
Enthusiast Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
u dont need camber kits....i have mines installed with some kybs and its cool..jus a 4-wheel alignment...the tech said i barely need an alignment....but for safety i did it neways....
BUT if you really decided to get camber kits...i have a set of obx kit for sale..pm me... -------------------- |
May 24, 2005 - 6:40 PM |
hmmm.. thanks guys! I'll contact those guys see how much they ring me. I'll get the camber kit when I want to lower my car even more =P
May 24, 2005 - 6:47 PM |
make sure you get ahold of chris and tell him jeff sent you. now that i think about it, it was a 4 wheel computized alignment for 100 i believe. ill check for reciept tonight
May 29, 2005 - 4:08 PM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
hey tom... did u get kyb gr2's also? and do u need them?
May 29, 2005 - 4:56 PM |
Enthusiast Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) |
i didnt even need to align my car after i popped in the springs. they showed me some computer printout of my car and the angles of the wheels etc they said it needed no adjusting
-------------------- i am awesome
Jun 2, 2005 - 12:21 AM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
i have some tein S springs and kyb gr2's on the way... any other helpful hints??
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jun 2, 2005 - 9:06 AM |
Enthusiast Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) |
QUOTE(Jaws4God @ Jun 2, 2005 - 1:21 AM) i have some tein S springs and kyb gr2's on the way... any other helpful hints?? [right][snapback]294263[/snapback][/right] Just make sure you have all the tools that you need. Also, be prepared for the rear, those sway bar links are a pain in the butt. Luckly from experience before hand with my GC's I knew what to expect when I replaced them with Teins. I just bought new links so I wouldn't have to deal with those old links anymore. Plus it's a good idea to replace since your car is getting older. I had a problem getting the OEM front shock cartridge out. Make sure you have a good vice and a plumbers wrench or something to unscrew that shock out. It's on there pretty tight. Well from what I experienced. We ended up taking it to a friends shop and he torched the shock out after draining the shock. The sealant that's on there is on pretty good. So just a heads up on that in case you come across it. -Christee- |
Jun 2, 2005 - 7:27 PM |
Enthusiast Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
Yeah, the sway bar links sucked my rear. One came off real easy, the other, well, a hacksaw solved that.
Jun 4, 2005 - 10:17 PM |
Enthusiast Joined Feb 17, '04 From milpitas CA Currently Offline Reputation: 0 (0%) |
QUOTE(tomazws @ May 24, 2005 - 8:15 PM) After I lowered the car with the S-Tech springs (0.9in front, 1.4in rear). The camber's totally off. The car's running like this: / \ (well not that extreme but u get the point...) I went to an alignment place to get a quote, and he said I'll need an camber kit to make the wheel perfectly straight (0 degree camber) Do I really? [right][snapback]291197[/snapback][/right] its 1.4 in front and .9 in back. After installing these on my car i did not need camber. |
Lo-Fi Version | Time is now: November 28th, 2024 - 3:34 PM |
