Tune Up Price, Maintenance |
May 25, 2005 - 10:17 AM |
Enthusiast Joined May 19, '05 Currently Offline Reputation: 0 (0%) |
Just got a quote for some maintenance items:
Replace Cap and Rotor Replace Fuel Filter Remove and Clean EGR Valve/vacuum hoses Replace valve cover gasket Add 1/2 pound freon $390 your thoughts? Any other imminent wear items to be replaced? Recently 15k miles ago: Replaced plugs Timing belts All fluids flushed and replaced (tranny, diff, power steer, and coolant) -------------------- ST204
78k |
May 25, 2005 - 10:22 AM |
The price above includes all parts and labor.
Also, got a quote which I'm putting off for fixing the emergency brake (the thing goes way up) for $220 parts and labor. My mechanic told me that there is a shoe on the Celicas that is separate from operating the calipers on the emergency brake. Is this true? He said fixing the emergency brake is not as simple as replacing or tightening the cable. True? -------------------- ST204
78k |
May 25, 2005 - 10:27 AM |
the price also depends on where you are located, prices in the California will be more then compared to other places in the USA. most of the stuff on the list i would do myself because it fairly easy to do.. ( cap and rotor, fuel filter) i would hold on changing the valve cover gasket untill there is a noticeable leak. (if it aint broken dont fix-it?) The only thing expencive on your list is the freon. |
May 25, 2005 - 10:29 AM |
yes there is a sperate pads for the emergency brakes.
and they are expencive to replace also, i had to send mine into get more brake material added on. for the most part, i would try adjusting the cable before changing the pads. |
May 25, 2005 - 10:46 AM |
Enthusiast Joined May 17, '03 From Florence, KY Currently Offline Reputation: 0 (0%) |
I don't know how much freon costs, but a month ago I paid $400 for a tune-up (plugs, wires, distributor cap), all new belts (except timing belt) and a new valve cover gasket. That is the total price parts and labor from the dealership.
May 25, 2005 - 11:34 AM |
Enthusiast Joined Feb 16, '03 Currently Offline Reputation: 1 (100%) |
damn
May 25, 2005 - 12:23 PM |
NEVER go to the DEALERSHIP
thats just stupid on drum brakes the e-brake and rear shoe is the same on rear disk brake you can only get the e-brake pad from the dealership you can get cap, rotor, plugs, wires, vavle cover gasket from advanced auto/ auto zone ect... for hella less and do it yourself cause its REALLY EASY you can even get freon from advanced as long as its R-134 if your R-12 then you need to go to a mechanic to have that done |
May 25, 2005 - 12:46 PM |
it really just depends on how much you know about cars and are willing to do. the cap and rotor are really easy thing to do, even if its your 1st time doing it. cleaning out the egr and doing the valve gasket isint hard either but might be too much to handel if you never worked on a car before. ... so its your call.. at least youll know toyota will do it right.
May 25, 2005 - 12:57 PM |
QUOTE(lagos @ May 25, 2005 - 10:46 AM) it really just depends on how much you know about cars and are willing to do. the cap and rotor are really easy thing to do, even if its your 1st time doing it. cleaning out the egr and doing the valve gasket isint hard either but might be too much to handel if you never worked on a car before. ... so its your call.. at least youll know toyota will do it right. [right][snapback]291645[/snapback][/right] Exactly why I go to the dealership. Plus it saves me a BUNCH of time. |
May 25, 2005 - 1:20 PM |
go to any mechanic they are still
105% of the time cheaper then toyota |
May 25, 2005 - 10:28 PM |
Enthusiast Joined Jan 28, '05 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
toyota tried to charge me 35 bucks to replace a battery (labor only) i said f*ck them, walked outside wit my battery and was off and runnin in 5 mins...that is about the easiest thing to do ever and they wanted 35 bucks for labor
-------------------- Speeding is only Illegal...
If you Get Caught |
May 26, 2005 - 9:22 AM |
advanced auto
FREE installation woot! and batteries at good prices mwhahaha 20$ for my battery |
May 26, 2005 - 12:20 PM |
player, your battery cost you 20$? what are you running, doubble A (AA) lol
oh wait, maybe you mean you got 20$ back as a core charge? -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 26, 2005 - 12:45 PM |
nope 20$ for a 35-1 battery!
but i worked at advanced auto and yea we have a few loop holes for stuff aka it was a "used battery" so that already makes it like 25$ and employee discounts mwahaha everything becomes very cheap! This post has been edited by playr158: May 26, 2005 - 12:47 PM |
Lo-Fi Version | Time is now: December 3rd, 2024 - 7:12 PM |
