> Tap for oil, 7afte
post May 25, 2005 - 10:26 AM
nk_pimpin18
Joined Oct 15, '04
From Muskegon
is there a sertain spot oh a 7afe where i should drill the hole for my oil return line?
post May 25, 2005 - 10:34 AM
nik
Joined Sep 30, '02
QUOTE(nk_pimpin18 @ May 25, 2005 - 8:26 AM)
[right][snapback]291561[/snapback][/right]
i would do the front of the pan where the drain plug is located and as high up as you can go check my HOW TO turbo a 7afe
here
This post has been edited by nik: May 25, 2005 - 10:36 AM
post May 25, 2005 - 8:14 PM
nk_pimpin18
Joined Oct 15, '04
From Muskegon
thanks alot, did you drill yours or did you buy a new one. im kinda scared to drill it dont want any metal shavings in my oil
post May 26, 2005 - 9:06 AM
nik
Joined Sep 30, '02
QUOTE(nk_pimpin18 @ May 25, 2005 - 6:14 PM)
[right][snapback]291847[/snapback][/right]
just remove the whole pan then drill and clean it out then reinstall it wink.gif
post May 29, 2005 - 3:04 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
after looking at the celica motor and seeing how other companys plumb the oil drain, id look for a spot higher into the block. when i get motivated (prolly months from now) ill try to boost this motor again.
Lo-Fi Version Time is now: December 1st, 2024 - 12:34 AM
