> 3sgte 02 sensor wire color?
post May 25, 2005 - 6:40 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
I just had my new 02 sensor put in, however I can't find my sensor wire from the ecu. What color is your 02 sensor wire. DG's wire is brown and my wiring diagram book says it should be brown. I don't have a brown wire. I have a blue w/ black stripe, yellow w/ green stripe, a white wire w/ a big black coating, a white wire, and a white w/ black wire.
I thought that I had a 93 motor, but the wiring book I have is for a 93. What color 02 sensor wire do you guys have?
post May 25, 2005 - 6:54 PM
look at your old o2 sensor. is it a signle wire one or a multi wire.
mine is a single wire, i think brown or black, but thats just going off memory. i can look at it again for you probably tomorrow.
post May 25, 2005 - 7:06 PM
jgreening
Joined Jan 17, '04
From Illinois
This doesn't have the color but its from a gen II 3sgte and has a notation to the O2 wire. Maybe it will be helpful.
wiring diagram
post May 25, 2005 - 8:28 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
I don't have the old sensor, i sold it with the old downpipe. All existing leftover plugs were cut, and the o2 sensor on accident. So I have a bunch of wires sticking out from there. I'm almost positive that the original sensor had only 1 wire. I looked at some of my old diagrams and then looked at the ecu plugs and think that the 02 wire is white on my car, which I have marked on my diagrams as ox1. I guess I'll give it a try tomorrow.
post May 26, 2005 - 5:41 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
Awesome, thanks for the help guys.
post May 26, 2005 - 8:01 PM
yes, white is correct.
Lo-Fi Version Time is now: December 4th, 2024 - 5:20 PM
