> Nitrous Install
post May 26, 2005 - 9:46 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
I was wondering if anyone had a website or any helpful information on how to install nitrous. More specifically on a 7A-FE. I'm thinking about purchasing nitrous, but I'm not sure yet. I wanted to know how difficult this would be. Thanks.
post May 26, 2005 - 9:53 AM
darksecret
Joined Mar 9, '05
From Charlotte
Determines what type of kit you use, a dry is about a 2/10, wet is 3/10, direct port is a 6/10 on difficulty. A new kit comes with a full set of instructions but you must consider bottle mounting location the top of the bottle should be facing towards the front of your car and angled about 30 degrees up so that with the label facing up because the pick up tube is shaped like an upside down straw and draws the nitrous from the corner of the bottle. the solenoids just need to be wired to a power source and switch, while the N2O solenoid connects to the bottle and the fuel solenoid connects to a fuel source. Get a bottle mounting kit, they are angled perfectly for nitrous flow.
post May 26, 2005 - 9:56 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
anyone have any pics of their nitrous install? i want to go for a wet kit.
post May 26, 2005 - 10:07 AM
darksecret
Joined Mar 9, '05
From Charlotte
This isn't mine but this is how it should look, of course this is a two bottle system but it works the same the second bottle is just to have more nitrous available for use:
This is a dry system that is opn a 350Z, seeing that the 350Z's fuel system can handle the juice it works well with a dry, as you see with the fourth pic the jet is mounted in the intake tube. A wet system is very similar to this just add another solenoid for the fuel and your jet should look like a Y.
post May 26, 2005 - 10:08 AM
darksecret
Joined Mar 9, '05
From Charlotte
As I gather more info on installs i'll add to my nitrous post in the engine tech section.
Lo-Fi Version Time is now: February 22nd, 2025 - 3:46 AM
