> minor engine knock when in idle, and at lower rpms
post May 26, 2005 - 9:18 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
probably been posted before but i couldnt find it. i have a minor engine knock (nothing serious and the noise cant really be heard outside of the car.) when my car is cold and in idle and also at lower rpms.
ive had this for a while and im guessing its normal for our engines but if it isnt feel free to post some possible problems.
post May 26, 2005 - 9:29 PM
Hanyo
Joined Aug 16, '03
From Bay area
are you thinking about the injectors ticking?
post May 26, 2005 - 10:46 PM
Jdog1385
Joined Apr 14, '03
possibley, didnt think of that. would injector cleaner do the trick or new injectors all together?
post May 27, 2005 - 2:01 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
the injectors for celica seems to be really loud but it is normal. I used to think that I had a problem with it when I first got the car as well.
post May 27, 2005 - 1:21 PM
we really dont know what you are hearing, i cant say that injector cleaner will fix it or not. if you can get a recording of the sound or something then that would help .
also, read this site:
http://remanufactured.com/Engine_Noise_Diagnosis_101.htm
post May 27, 2005 - 2:10 PM
how many miles on the engine? could need a valve shim adjstment..i think the BGB calls for them every 60k
post May 27, 2005 - 3:27 PM
maikl
Joined Mar 3, '03
From cyprus
check your injectors they propably need cleaning .. or sparks.
post May 27, 2005 - 4:31 PM
Jdog1385
Joined Apr 14, '03
the minor knock is the loudest at lower rpms but when the car warms up the noise is less. the engine does have a lot of miles on it...about 115k but i keep it in good shape and there is defintely no leaks. i havent changed the injectors yet but i recently did a tune up.
as for a valve shim adjustment....what is that exactly?
and what is a good way to clean the injectors.
ill definitely try to do that or if not, hopefully the the engine will be making the noise when im at lsp in a week. but i doubt it will b/c the engine will be warmed up.
This post has been edited by Jdog1385: May 27, 2005 - 4:34 PM
post May 27, 2005 - 4:35 PM
Jdog1385
Joined Apr 14, '03
When the engine is cold, the aluminum piston is small in comparison to it's iron cylinder. Therefore the rather hollow slapping noise will be loudest first thing in the morning. After the engine warms up, the aluminum piston heats up faster than it's iron cylinder, cutting down on the excessive clearance between the piston and cylinder wall.
- this is a quote from that site. sounds about right. might be a possible diagnosis.
post May 27, 2005 - 8:05 PM
Hanyo
Joined Aug 16, '03
From Bay area
Valve shimes are adjustable where the top of the valve stem meets the rocker arm. As an engine wears, the tolerence between the valve train start to grow and loosen. So adjusting the valve shims is a way to help bring the tolerence back to specs.
I would personally let a dealer ship do this, because it requires you to use a feeler gage. It require experience to know how much adjustment is right.
post May 27, 2005 - 8:19 PM
buy a car stethoscope at sears ! all you can do is guess, but with that it will tell you the location of the sound for sure.
post May 28, 2005 - 2:52 AM
perry190
Joined Nov 18, '04
From UK
in principle you wont be getting knock until the car is under load, so I would suggest your problem (if there is one) is else where
post May 28, 2005 - 8:20 AM
Jdog1385
Joined Apr 14, '03
im gonna try to take a audio clip of it today
post May 28, 2005 - 9:44 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
QUOTE(Jdog1385 @ May 27, 2005 - 4:35 PM)
[right][snapback]292511[/snapback][/right]
Mine did that today, my friend heard it a bit, his reasoning was that the oil pressure hadn't gotten up in those first couple cranks.
I have another wierd sound though, I need to check on it, I may be back for help on it too.
Lo-Fi Version Time is now: November 28th, 2024 - 2:00 AM
