Q about wiring, directly from battery or cig lighter? |
May 26, 2005 - 10:00 PM |
Enthusiast Joined Sep 17, '03 From Tampa FL Currently Offline Reputation: 1 (100%) |
I was wondering if there was a power difference from the battery and say the cigarette lighter? If i took a 12v light that was wired to the cig lighter and hooked it up directly to the batt, would that make a difference? It just seems to me that a lil 12v bulb would explode if i hooked it up to the terminals of a car batt. Is there a difference in amps? could i light a 74 bulb straight from the battery?
-------------------- -97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre (GOT LIFT?) |
May 26, 2005 - 10:25 PM |
yes. there is really no difference. I'm sure you will find lots of members that use the lighter for power for neons, swiches, ect. If you are worried about a voltage drop or surge either use a relay or an inline fuse for saftey.
May 27, 2005 - 4:23 AM |
the thing you have to worry about is the gauge of the lighter wire.
Its not a very thick wire; So if you pull too much current through it, the wire might melt. |
Lo-Fi Version | Time is now: December 1st, 2024 - 5:01 AM |
