URGENT: Air Bag light, went on |
May 29, 2005 - 11:20 AM |
Enthusiast Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
Ok guys, yesterday i had a shop cut a hole in the inner fender right next to the battery, well long story short the wires in a yellow loom that go somewhere into the drivers high beam got tangled in the air grinder, the insulating tore open and caused the copper wire in the wires to become exposed, i separated them and wrapped them in black tape, but now the air bag warning light came on in the dash and wont go away, anybody know what to do?
May 30, 2005 - 2:35 AM |
Enthusiast Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
Personally, i'd take it to a professional mechanic or (gasp) toyota. The airbag is NOT something you should be screwing with.
-------------------- AIM : FAQdaWorld
May 30, 2005 - 2:56 AM |
first make sure all of the wire connections are secure. Then try to reset the ECU by taking off the negative nattery terminal, waiting 30 sec, then reconnecting it. If the light still stays on, then taking it to a Toyota dealership to have it reset is probably the only other option. If you talk to the guys at the dealership they will probably do it for free, should take a few minutes.
May 30, 2005 - 3:58 AM |
Enthusiast Joined Jul 27, '04 From phoenix az Currently Offline Reputation: 0 (0%) |
you prabably messed up a sensor in the front of the car.mine came on when i cut my springs a while back i hit a huge bump on the road and it came on.
May 30, 2005 - 10:54 AM |
Enthusiast Joined Apr 22, '04 From Rhode Island Currently Offline Reputation: 3 (100%) |
id have the shop pay to fix it, they screwed it up in the first place
May 30, 2005 - 11:26 AM |
Cant take it to toyota, most of them are a-holes, i know for a fact that those wires are for the sensor in front of the car, im just wondering if the bags will blow.
trdevelopment, what did you do to fix the problem? |
May 31, 2005 - 5:24 AM |
nothing the air bag is still on lol i think i will eventually pull out the cluster and yank the abs light off.(keep in mind if the abs light is on IF you get in a accident the air bags WILL NOT DEPLOY).i just dont have the money to change the front sensor. i think playr yanked out his also.
Jun 1, 2005 - 3:11 AM |
QUOTE(Batman722 @ May 30, 2005 - 2:56 AM) first make sure all of the wire connections are secure. Then try to reset the ECU by taking off the negative nattery terminal, waiting 30 sec, then reconnecting it. If the light still stays on, then taking it to a Toyota dealership to have it reset is probably the only other option. If you talk to the guys at the dealership they will probably do it for free, should take a few minutes. [right][snapback]293235[/snapback][/right] have you tried this yet ? -------------------- |
Jun 1, 2005 - 3:21 PM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
I agree with batman!
Jun 1, 2005 - 11:27 PM |
yes i tried the battery thing, didn't work.
trd, what do you mean abs light? im talking air bags! |
Aug 4, 2005 - 3:33 PM |
Enthusiast Joined Jul 7, '04 From Maryland Currently Offline Reputation: 0 (0%) |
QUOTE(Batman722 @ May 30, 2005 - 7:56 AM) first make sure all of the wire connections are secure. Then try to reset the ECU by taking off the negative nattery terminal, waiting 30 sec, then reconnecting it. If the light still stays on, then taking it to a Toyota dealership to have it reset is probably the only other option. If you talk to the guys at the dealership they will probably do it for free, should take a few minutes. [right][snapback]293235[/snapback][/right] my air bag light just came one and wont go off , I'm gonna try what you said |
Aug 4, 2005 - 3:57 PM |
the battery trick didnt work, i'll have the dealer check it out. tomorrow
Aug 6, 2005 - 12:31 AM |
dealer said I need a new ecu 500 bucks
Aug 6, 2005 - 10:54 AM |
yup, you ( or they) prolly fried the airbag ecu..if you dont wanna fix it, i sugest disconnecting the airbag ecu , (MAKE SURE YOUR BATTERY IS DISCONNECTED WHEN YOU DO IT! lol) cause id be worried about the airbag going off for no particular reason, and that would suck.
13.6@108MPH, 5SFTE Powered |
Aug 7, 2005 - 1:14 AM |
yea my air bag light is on because i rear ended a truck i don't know where the senosr is to yank it out so i just kinda deal with the light being on when i go for inspection i'll pull the bulb out and ust get over it.....i'm goin to install 4 point belts to hold me in a lil tighter though
but i don't expect my bags to go off next time i wreck....so i don't plan on wrecking |
Aug 7, 2005 - 2:34 AM |
QUOTE(playr158 @ Aug 6, 2005 - 11:14 PM) yea my air bag light is on because i rear ended a truck i don't know where the senosr is to yank it out so i just kinda deal with the light being on when i go for inspection i'll pull the bulb out and ust get over it.....i'm goin to install 4 point belts to hold me in a lil tighter though but i don't expect my bags to go off next time i wreck....so i don't plan on wrecking [right][snapback]321410[/snapback][/right] The sensors are on the sides of the A/C condenser. You have to pull the condenser to access the two Torx bolts per side to remove/replace them. But back to your original question, I would for sure make the shop who did the damage pay a good Toyota dealer(you may have to go out of town) to fix it. Airbags can save your life and you don't want just anyone messing with them. -------------------- New Toyota project coming soon...
Aug 8, 2005 - 3:56 PM |
EXACTLY
Aug 24, 2005 - 7:00 PM |
Enthusiast Joined Aug 22, '05 From Tucslown, AZ Currently Offline Reputation: 0 (0%) |
cant you just pull a fusible link to disable the whole system, including the light? Theres got to be a better way to get the ab light off than discnonecting the bulb... Both my bags were deployed and cut out so I also need to rid of this light, whats the best way? Which fuse do i pull?
Also, whats the best way to get pass bag flap down? I wanted to replace with lcd monitor but doesnt look like will fit. Dont want to take whole airbag out, just get flap down. |
Aug 25, 2005 - 3:30 PM |
just push it down use some epoxy to hold it....
you pull out the fuse and you will fail inspection even easier...... seriously the best way is just take out the bulb it honestly takes 5 min to take it out pull the bulb and put it back in |
Lo-Fi Version | Time is now: January 11th, 2025 - 4:52 AM |
