Stupid exhaust question |
Apr 17, 2003 - 11:07 AM |
Enthusiast Joined Aug 30, '02 From Ohio Currently Offline Reputation: 0 (0%) |
WTF is mandrel bent piping??
-------------------- Jared Harwell
Apr 17, 2003 - 11:38 AM |
mandrel bends are smooth, versus "crush" bends where the bends have like ribs in them, which restricts airflow.
13.6@108MPH, 5SFTE Powered |
Apr 17, 2003 - 11:40 AM |
AHhhhh
so its the same as when they bend the exhaust piping in that machine?? -------------------- Jared Harwell
Apr 17, 2003 - 11:47 AM |
<~~dont know...im really not all that good with that stuff...lol just happen to know the diffrence between the two..
Apr 17, 2003 - 5:14 PM |
Enthusiast Joined Dec 1, '02 From minneapolis Currently Offline Reputation: 0 (0%) |
i'm pretty sure they need a better machine to do mandrel bends. i think they stretch them as they are bending them or something. i'm not positive on the process of making them.
but the bends have the same cross sectional area as the straight parts of the piping. in crush bending, the bends have a smaller cross section, which is restrictive |
Apr 17, 2003 - 6:07 PM |
Enthusiast Joined Aug 30, '02 From Rolla, Misery (Missouri) Currently Offline Reputation: 0 (0%) |
Mandrel bends don't restrict the air-flow. Crushed bends do, as stated above. If a shop has a machine that bends piping, I really doubt that it's one that does mandrel bends. Every muffler shop has crush bent machines though. It's a heck of a lot cheaper to go crushed, and most people don't know the difference. If you are serious about performance the mandrel bends are the way to go. The Greddy SP exhaust, as well as all their other exhausts, are mandrel bent. The metal on the inside of the curve is thinner and the outside of the curve is thicker, thus air flows smoothly around the curve. Hope that helps.
Nathan |
Apr 17, 2003 - 7:09 PM |
Enthusiast Joined Feb 18, '03 From UK Currently Offline Reputation: 0 (0%) |
When you bend a pipe using a crush style machine the diameter of the pipe will vary, so at the bend due to the crushing process the diameter of the pipe will become smaller hence restricting the air flow.
Now mandrel pipe bending, im not too sure on the process, but the result is a piping bent to what ever required, whilst maintaining the original desire diameter of piping throught out, including on bends, thus retaining the desired free flow of the pipe. If you get me, i hope ive explained it clearly, but anyhow, thats pipes! |
Apr 17, 2003 - 7:22 PM |
Either way, your not going to feel a difference in power/performance on our Celica's.
Apr 17, 2003 - 7:29 PM |
Not necessarily, as if a bend is crushed too much the exhaust could be more restrictive than stock And the whole idea of buying an aftermarket exhaut is to try to achieve a little more performance, than stock! |
Apr 17, 2003 - 9:36 PM |
well, im not talkin about exhaust work, im wanting to make a new CAI, and i saw where someone used 2.5" piping, and i was just wondering if i could get it at a muffler shop.
Apr 17, 2003 - 9:47 PM |
ya you can
or get cheaper pvc pipe. i think that works better This post has been edited by igotta5S-FEturbo: Apr 17, 2003 - 9:47 PM |
Apr 17, 2003 - 10:45 PM |
I already have the PVC pipe. Im needing something smaller diameter cause of my hood. The vents hit the CAI.
Apr 17, 2003 - 11:22 PM |
Enthusiast Joined Apr 8, '03 From NorCal Currently Offline Reputation: 0 (0%) |
2.5" exhaust is too big for a n/a 4 cylinder anyways...;P You'll actually lose just as much power as crush bent pipes... |
Apr 17, 2003 - 11:28 PM |
That's ghetto...pvc pipes...;] I have a 3" mandrel bent steel pipe... ordered it from JC whitney, then again, mine's an ST. For the GT... after looking at the engine bay, it'll be a tight squeeze, but I bet you can get away with a 3" pipe if you're clever. Shoot, I've even designed and made a CAI for a 91 Lude si... Now that's a tightly cramped engine bay... I have pics somewhere. Anyways, for the GT, just off the top of my head, you'll probably need 3 separate bends just to get the right shape. One short one off of the throttlebody, one pointing down away from engine bay, and one off the down, to the driver-side fender. I bet it's doable...I mean, I managed to fit a Civic intake in an 91 MR2...;] |
Lo-Fi Version | Time is now: November 24th, 2024 - 9:32 AM |
