> alarm wire question, mainly about the doors
post Jun 1, 2005 - 4:34 PM
Terzin1
Joined Feb 19, '05
From Indianapolis
first off, i need to know whether my celica, which has power locks, runs off negative switching door pin switches or postive 12 volt door pin switches. also, there is a wire that hooks to the brain of my alarm to detect if someone gets in the car through my trunk, does anyone know what wire to splice that into? my alarm system is a crimeguard 745i
For the best designs and screen printing.
WE DON'T PRINT UGLY.
www.TERZink.com
post Jun 1, 2005 - 4:37 PM
Terzin1
Joined Feb 19, '05
From Indianapolis
i read coomers guide but still cant find the door trigger wire in the kick panel, there are a ton of red/white wires under there.
www.TERZink.com
post Jun 1, 2005 - 4:42 PM
DmVinny
Joined Feb 23, '03
From Florida
Actually Pali_playa's alarm thread is better but;
Power Lock is Blue/Black and its negative located under the steering column its a small black box.
Power Unlock is Blue/Green and is Negative as well.
And the turnk pin which is negative is on the drivers side kick panel and is Red/Green
post Jun 1, 2005 - 5:06 PM
Terzin1
Joined Feb 19, '05
From Indianapolis
that info is usefull, but i need to know about the door pin switches cause i have to either connect a positive of negative wire to the pin switch wire so my alamr knows when the doors are opened. i guess im just having trouble finding the wires i need cause there are a ton in the kick panel
This post has been edited by Terzin1: Jun 1, 2005 - 5:08 PM
www.TERZink.com
post Jun 1, 2005 - 5:24 PM
It's a negative door trigger. Test the red and white wires and find the one that gives you +12 volts with both doors closed and ground with either(or both) doors open. I may have a picture of exactly which wire you need to tap into at home.
And I'm not sure about the trunk pin. I do know that on hatchbacks it's tied into the door pin circuit, but not on coupes.
post Jun 1, 2005 - 5:50 PM
Terzin1
Joined Feb 19, '05
From Indianapolis
can you post what that picture coomer? there was obviously an alarm in my car before i bought it and the guy must have removed it because alot of the wires i am using are already cut and respliced back together, i can find any that were cut for the doors tho
This post has been edited by Terzin1: Jun 1, 2005 - 5:51 PM
www.TERZink.com
post Jun 1, 2005 - 6:36 PM
Yeah, I'll look when I get home. I'm off work in twenty minutes and then I'm probably going straight home.
post Jun 1, 2005 - 6:40 PM
Terzin1
Joined Feb 19, '05
From Indianapolis
ok, i found a wire that goes to 12+ volts when the drivers door is closed and no reading when its opened. however, the reading is not effected when the pass. door is opened or closed. did i find the wrong wire? btw, i dont htink convertibles have the option to have the dome lights come on when the doors open like the other celicas.
damn it, why is it that the passengers side coutesy light (the red light that lights up when you open the door thats ON the door) only lights up when the drivers door is open? if i open only the passengers side door, the light doesnt go on. that must be affecting something
This post has been edited by Terzin1: Jun 1, 2005 - 6:51 PM
www.TERZink.com
post Jun 1, 2005 - 6:56 PM
Let me guess. The wire you found is red with a yellow stripe, right? There's one that's seperate for the driver's door(for the auto off headlights and such), and at some point it combines with the red/white wire(I think at the integration relay.)
post Jun 1, 2005 - 7:00 PM
Terzin1
Joined Feb 19, '05
From Indianapolis
i didnt try any red and yellow wires but now i have found 3 wires that are only affected by the drivers door!!!!
www.TERZink.com
post Jun 2, 2005 - 9:40 AM
Terzin1
Joined Feb 19, '05
From Indianapolis
i think i found the problem, the passengers side door trigger isnt working, that is the only solution. Now i need to locate where in the hell the problem is. is the door open light in the dash light up when everyone elses pass. door is open? what does it mean when the red/white wire right next to the pass. side trigger registers 12 volts no matter if the door is opened or closed?
This post has been edited by Terzin1: Jun 2, 2005 - 11:10 AM
www.TERZink.com
post Jun 6, 2005 - 3:05 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Terzin, your in luck, as I am doing a alarm job on my convertible. What actual wires do you need so i can take pics?
Lo-Fi Version Time is now: November 28th, 2024 - 6:57 PM
