> how to, the damn fender
post Jun 2, 2005 - 2:36 PM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
yesterday i wanted to run my wiring through the harness hole that is near the battery. the stock harness is runs near the battery, in the fender and then into the interior. i remove the 3 bolts on the top, the nuts that connect the bump and fender. the bolt near the door, the other bolt in the inner fender near the door, and the two under near the front side skirt. then remove the fender mud lining. i tried too pull it off but i couldnt do it like it was still stuck ??? any suggestions?
post Jun 2, 2005 - 2:52 PM
3 bolts on top inside the engine bay
1 bolt inside the door
1 bolt inside the fender near the door
3 bolts inside the fender that connect front bumper
2 bolts under headlight
2 bolts under car
how to-
remove front bumper
- remove bolts inside engine bay going across bar (4)
- remove bolts holding plastic to bottom of bumper (?)
- remove bolts that connect bumper to fender (3 per side)
remove low beam
- two on top one on bottom (3 per light)
remove fender
- remove bolts from under headlight (2)
- remove bolts inside engine bay (3)
- remove bolt inside door (1)
- remove bolts inside fender (1)
- remove bolts undercar (2)
This post has been edited by playr158: Jun 2, 2005 - 2:56 PM
post Jun 2, 2005 - 3:27 PM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
thanks
post Dec 4, 2014 - 3:32 AM
specter1001
Joined Dec 18, '11
From Honolulu, HI
QUOTE (playr158 @ Jun 2, 2005 - 3:52 PM) *
2 bolts under car
how to-
remove front bumper
remove low beam
remove fender
are all these bolts 10mm?
post Dec 4, 2014 - 9:58 AM
more than likely its been like 9 or 10 years since i did it last laugh.gif tongue.gif
post Dec 5, 2014 - 1:25 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (specter1001 @ Dec 4, 2014 - 1:32 AM) *
2 bolts under car
how to-
remove front bumper
remove low beam
remove fender
Some of them are.
God made man....
Everything else...
Made in China
post Dec 7, 2014 - 5:56 AM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (nics @ Dec 5, 2014 - 2:25 PM) *
2 bolts under car
how to-
remove front bumper
remove low beam
remove fender
Some of them are.
All of them should be 10mm, i just checked since i had my front bumper off.
This post has been edited by Noahwhite2014: Dec 7, 2014 - 5:56 AM
Lo-Fi Version Time is now: February 22nd, 2025 - 1:10 AM
