gauge pods |
gauge pods |
Jun 6, 2005 - 11:35 AM |
dude i no like very little about 02 sensors and crap
a normal air/fuel does NOTHING for you if your boosting cause it can't read that much i wouldnt even try that on my pos 7afe when i turbo wideband o2 and boosting go hand in hand get a clue |
Jun 6, 2005 - 11:48 AM |
Enthusiast Joined Sep 28, '03 From Bloomington, IN Currently Offline Reputation: 0 (0%) |
Dan, I'm guessing your new here. Here's a tip. There's a couple people on this site not to fight with. When it comes to mechanical stuff, just take advice from lagos and jay, don't fight em, they're very informative.
Joker, for nitrous, congrats on wanting to go with a nitrous pressure gauge up front. Those are pretty expensive, but you're playing safely and I like that. If you have another slot to fill, fuel press would be nice. Course, it's helpful for the first dyno run. After that it should remain constent. As I understand it. -------------------- NASA/SCCA RX-7....currently under the knife
92 Civic hatch B16 - Sold 10th anniv RX-7 - RIP The Slow Celica - Sold...and then crushed crushed due to street racing. Quote from Seinfeild: George's Boss reading a magazine: "People magazine's most beautiful people. Oh and a Celica...nothin wrong with that!" |
Jun 6, 2005 - 1:27 PM |
Enthusiast Joined Apr 23, '05 From kent Currently Offline Reputation: 0 (0%) |
right normal lambda probes operate within certain parameters under a closed loop inside the stoichometric rule (roughly 14:1) and give an output voltage. However they cannot provide an extremely accurate air/fuel ratio which is necessary for control while tuning. Wide band sensors use a different method of air/fuel measurement which is more accurate and can work out how far from the stoichometric rule that the ratio should be even when the readings are extreme
Correct? You can still keep a rough idea on what air/fuel ratio you have with a narrow lambda probe. Obviously if you run too rich you bore wash, and too lean you overheat. Anyway i only asked about gauges lads, peace |
Jun 6, 2005 - 1:31 PM |
this wasnt aimed at an argument lads, just bcause there's a newbie here dont assume i am unintelligent. Part of our workshop runs its own rally team
Jun 6, 2005 - 1:38 PM |
check it out......
Jun 6, 2005 - 1:51 PM |
QUOTE(dan4 @ Jun 6, 2005 - 1:27 PM) right normal lambda probes operate within certain parameters under a closed loop inside the stoichometric rule (roughly 14:1) and give an output voltage. However they cannot provide an extremely accurate air/fuel ratio which is necessary for control while tuning. Wide band sensors use a different method of air/fuel measurement which is more accurate and can work out how far from the stoichometric rule that the ratio should be even when the readings are extreme Correct? You can still keep a rough idea on what air/fuel ratio you have with a narrow lambda probe. Obviously if you run too rich you bore wash, and too lean you overheat. Anyway i only asked about gauges lads, peace [right][snapback]295509[/snapback][/right] Looks like you did some searching on the internet. Although you should have done that in the first place, I commend your effort. However, I still take issue with the notion that a narrow band 02 sensor (or an a/f guage with a narrow band) provides anything useful above 300 r.p.m. QUOTE(dan4 @ Jun 6, 2005 - 1:31 PM) this wasnt aimed at an argument lads, just bcause there's a newbie here dont assume i am unintelligent. Part of our workshop runs its own rally team [right][snapback]295513[/snapback][/right] Nobody ever said you were unintelligent - just uninformed. We were all uninformed once so that isn't really a problem - this place is about learning afterall. The problem occurs when you provide information as if its true when you are not sure. One idea might be to just say "I think" before your statement. If you say, "I think a a/f guage can be useful for turbo applications", I would not feel very sorry for the guy that went out and purchased one because of your statement. Best regards. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jun 6, 2005 - 4:34 PM |
Jun 7, 2005 - 12:30 PM |
QUOTE Looks like you did some searching on the internet why thank you, no need to be insulting |
Jun 19, 2005 - 6:31 PM |
Enthusiast Joined Mar 6, '03 From South Central Los Angeles and Long Beach, CA Currently Offline Reputation: 1 (100%) |
hey quick question, does anyone know where to get a RHD gauge pod HERE in the STATES??
David |
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:38 PM |
