How should i run 4 tens off one 800 watt amp?, any help. |
Apr 17, 2003 - 8:54 PM |
Well i have an 800 watt amp. its bridged and powering two tens. at 400 watts each. ok. so i bought two more identical subs same wattage, brand name ect. Can i run all four off one 800 watt amp if i have it bridged and in series?? thanks any comments
should i just buy a 1600 watt amp 4 ch? and a 2 farrad cap? This post has been edited by x_itchy_b_x: Apr 17, 2003 - 9:25 PM -------------------- |
Apr 18, 2003 - 9:24 AM |
Enthusiast Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) |
Need to know the specs, then i could tell you. Specs of both the subs and amp. 'cause if u break the ohm down to much you can fry the amp by trying to run that many subs. Depends on what its capable of handling.
Apr 18, 2003 - 11:03 AM |
The Subs:
10" subwoofer for deep bass 400-watt peak power-handling capacity 120-watt continuous power-handling capacity IMPP (injection-molded polypropylene) woofer cone for durability, accuracy and efficiency Durable dual-layer urethane surround Impedance: 4 ohms Large strontium magnet Inverted IMPP dust cover 4-layer copper voice coil Frequency response: 20Hz - 4.5kHz 1.0 cu. ft. sealed, ported or band-pass enclosure recommended The Amp: Two channel Amplification 2 x 400 watts Max Output 2 x 250 watts RMS Output 1 x 800 watts Bridged Stable at 2 ohm stereo Fully adjustable Electronic Crossover Variable (0 ~ 12 dB @ 60 Hz) Bass Boost Digital VU Level Meters Plexiglass Top Panel Soft Ignition Power up MOSFET PWM Power Supply Heavy Duty Aluminum Alloy Heat sinks High / Low Level Inputs Gold Plated High Impedance Inputs High Level MOLEX Input Power and Protection LED Indicators Signal to Noise Ratio >95dB Frequency Response: 15 ~ 30,000 Hz Total Harmonic Distortion: <0.04% Fully Protected Circuitry Dimensions: 10.5" W x 2.15" H x 16.5" L Variable Gain Control Remote Activation My amp is alos only running on 8 guage wire. should i get 4? also do i need a cap? i heared you need one farad every 800 watts This post has been edited by x_itchy_b_x: Apr 18, 2003 - 11:09 AM -------------------- |
Apr 18, 2003 - 2:26 PM |
ok run 2 subs per channel
it will work fine and yea get atleast a 1 farad cap. |
Apr 18, 2003 - 3:00 PM |
Enthusiast Joined Jan 29, '03 From Texas Currently Offline Reputation: 0 (0%) |
damn ure car will be even more slow hehe
Apr 18, 2003 - 5:12 PM |
yeah it seems to work good this way. im going to buy the cap today. -------------------- |
Lo-Fi Version | Time is now: November 28th, 2024 - 12:08 AM |
