Wheel hopping, Excessive front left wheel hopping |
Oct 5, 2005 - 4:48 PM |
mikew
i put in brand new mounts on the front and rear, but only filled the rear mount with the poly. im happy to report that i have zero vibration inside the car and the mounts made a huge difference in throttle response and the general feel of the car. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Oct 5, 2005 - 6:07 PM |
Enthusiast Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
awesome
I think im going to have to fill mine in when I get a few days where I don't need my car. -------------------- |
Oct 6, 2005 - 3:44 AM |
Enthusiast Joined May 24, '05 From Malta Currently Offline Reputation: 0 (0%) |
No guys its not me its the car. Even at a normal stop go 1200rpm laounch I have some wheel hop.
I will try to but the rear mount as well and fill with poly. Thanks for your help. will keep you posted. |
Oct 7, 2005 - 2:49 PM |
I never thought that motor mounts can be worn out......
Oct 7, 2005 - 3:01 PM |
QUOTE(soulshadow @ Oct 7, 2005 - 2:49 PM) I never thought that motor mounts can be worn out...... [right][snapback]342262[/snapback][/right] its just rubber...overtime it cracks and wears out -------------------- 15PSI - 30MPG - Megasquirt Tuned
Oct 12, 2005 - 5:23 AM |
6gen
You see it was not me! I found some time to get the rear mount out, or whatwas left of it! Will buy a new one from Toyota and fill with poly. Hope this was the caouse of the wheel hopping!! Thanks to everyone for thier suggestions! |
Oct 12, 2005 - 5:24 AM |
You see it was not me! I found some time to get the rear mount out, or whatwas left of it! Will buy a new one from Toyota and fill with poly. Hope this was the cause of the wheel hopping!!
I took a photo of the blown mount. How do I add it? Thanks to everyone for thier suggestions! |
Oct 12, 2005 - 5:26 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
You need to host the pic somewhere. If you like you can email it to me and I'll host it for you.
drtweak@phoenixtuning.com -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Oct 12, 2005 - 11:06 AM |
Oct 12, 2005 - 11:12 AM |
good job you found the issue
Oct 12, 2005 - 1:53 PM |
WOAH!!!
Oct 13, 2005 - 3:12 PM |
ummm..yeah that would do it...lol
Oct 14, 2005 - 3:35 AM |
Went to toyota today. Guess what they do not have the mounting in stock. They have ordered it by air freight and should take a week to arrive. So Celica will be off hte streets for a week. Will take the opportunity to fit the front M's brake pads I just bought and maybe fit the 4-1 exhaust header which has been lying in the garage for months now.
I was thinking to put back the catalyst as well as in my opinion there is not much difference without it except for the noise level. One good thing about the mount is that it only costs $42 and about the Toyota dealer is that he is stocking TRD parts as well. |
Nov 16, 2005 - 7:16 AM |
Finally the Celica is back on the road. This is what it went through in the last month:
Replaced front and back engine mountings filled with polytherane Installed 4-1 header with decat pipe to match the rest of the exhaust Removed the Blitz SUS filter and installed the original air box witha new Toms' panel air filter Removed the resonator pipes in the fender for the Air box and routed a flexible pipe to the front of the engine Replaced right hand side drive shaft bellows Replaced brake pads Results: A bit of vibration inside but not excessive, but magically all the wheel hopping disappeared :-) Header made a good difference for to end power but I feel I have lost some torque at the mid range. Overall I'm quite satisfied. |
Lo-Fi Version | Time is now: December 2nd, 2024 - 6:46 PM |
