Another Swap Question?, Need some info on exact parts |
Jun 5, 2005 - 10:50 PM |
Enthusiast Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
If you go with a 2nd gen you will beable to get alot of after market parts & stock parts because the 2nd gen came to the U.S. on the mr2...
Jun 6, 2005 - 11:41 AM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
QUOTE(Punch @ Jun 6, 2005 - 3:50 AM) If you go with a 2nd gen you will beable to get alot of after market parts & stock parts because the 2nd gen came to the U.S. on the mr2... [right][snapback]295327[/snapback][/right] 1st and 2nd gens also came in the celica all-trac. |
Jun 7, 2005 - 12:54 AM |
I'd go with 3rd gen. The engines all share the same "Essential" parts, such as waterpump, timing belt, gaskets, etc... The Only major differences is the intercooler, turbo, and ECU (MAP)...
-------------------- "It's ok to be naked girl... I'm an artist!"
Jun 7, 2005 - 5:24 AM |
Enthusiast Joined Mar 9, '03 From Orting, WA Currently Offline Reputation: 0 (0%) |
QUOTE(Rjb23 @ Jun 5, 2005 - 9:11 PM) QUOTE(sapperk @ Jun 6, 2005 - 1:07 AM) so your saying the 2nd and 3rd gen both fit with no problems [right][snapback]295298[/snapback][/right] Have your researched this at all? A 3sgte is a 3sgte, they both mount the same way. The wiring is going to be different from year to year. There are a few suttle differences between generations, types of turbo's etc.. You really should take the time and search. [right][snapback]295299[/snapback][/right] Alrighty then,,, this is what i mean by the silly arguments. This whole web site is about what everyone has done, correct? Ive done a lot of research, and searching on here, read all the forums, and this would be called researching also. The only way to know if something is a sure thing when it comes to swapping is to talk to people that have already did it. The things im trieing to find out is like the wiring, you say on certain years the wiring is different. Well those are the things i want to know. As for rushing into things, i have not bought anything yet. And im not purchasing in till i have all the facts. This post has been edited by sapperk: Jun 7, 2005 - 5:25 AM |
Jun 7, 2005 - 9:55 AM |
QUOTE(Kwanza26 @ Jun 7, 2005 - 12:54 AM) I'd go with 3rd gen. The engines all share the same "Essential" parts, such as waterpump, timing belt, gaskets, etc... The Only major differences is the intercooler, turbo, and ECU (MAP)... [right][snapback]295763[/snapback][/right] Here is a list of differences: - MAP sensor instead of AFM - Bosch D-Jetronic (Gen III) vs. L-Jetronic (relatively primitive) engine management - CT20b turbo replaces CT26 - Boost raised from 10psi to 13psi - Fuel cut raised from 12 psi to 18 psi - Different ECU - 4 wire O2 sensor - Shim under bucket valve shims - slightly more aggressive cams - Revised internals (pistons, con-rods etc.) - Revised cylinder head cooling passages/water jackets - Revised intake manifold (8 'independent long ports' reduced to 4) - intake manifold inlet air temperature sensor added. i.e. after turbo and intercooler. - lower compression ratio - stainless steel head gasket - factory 540cc injectors replace 440cc injectors - revised fuel rail with bigger bore and relocated pressure regulator - TVIS eliminated - EGR eliminated - throttle body increased from 55mm to 60mm - inlet valve lift increased from 8.2 to 8.7 - intake manifold inlet air temperature sensor added - Less restrictive exhaust elbow - Aluminum oil pan - more rigid alloy sump and additional oil baffles - Factory Catch can - Better Oil Cooler and relocated oil filter (bottom) - 4 Channel ABS coupled with Traction Control available - No. 1 compression ring described as 'stainless steel' instead of just 'steel'. Oil ring is described as 'stainless steel' instead of 'a combination of steel and stainless steel'. - The fuel pressure raised from 36 PSI (2.55 bar) to 41 PSI (2.9bar) - air to air intercooler is replaced with air to water intercooler. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jun 7, 2005 - 10:12 AM |
Enthusiast Joined Sep 28, '03 From Bloomington, IN Currently Offline Reputation: 0 (0%) |
keep in mind, I doubt you wanna put a an OBOI engine into ur OBOII car. It can be done, but what a wiring headache.
-------------------- NASA/SCCA RX-7....currently under the knife
92 Civic hatch B16 - Sold 10th anniv RX-7 - RIP The Slow Celica - Sold...and then crushed crushed due to street racing. Quote from Seinfeild: George's Boss reading a magazine: "People magazine's most beautiful people. Oh and a Celica...nothin wrong with that!" |
Jun 7, 2005 - 4:56 PM |
Enthusiast Joined Mar 21, '04 From Oceanside Currently Offline Reputation: 2 (100%) |
QUOTE(BBoYRuGGeD @ Jun 5, 2005 - 1:15 PM) QUOTE(Yota @ Jun 5, 2005 - 7:36 AM) Will they sell the odds and ends that one might need for the swap separately? [right][snapback]295203[/snapback][/right] i dont believe so... bboy [right][snapback]295220[/snapback][/right] Not at all! I have tried in person, over the phone, internet, everything. I have a few parts I am looking for that came up missing during the swap and can't get them. |
Jun 9, 2005 - 5:12 AM |
This is a good thread about some of the differences between the gen II and gen III motors:
Built Gen II or Built Gen III Pay particular attention to the posts by RickyB and ChrisC. My synopsis if you don't want to read the whole thing is that if your goals are 330whp or under, the Gen III is the way to go (not taking into consideration parts availability issues). If your goals are more than that, both will do the job but there are some good reasons to go with the Gen II. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jun 9, 2005 - 6:26 AM |
thanks for all the info, now i can make a decision here soon, i hope.. Rip Mods or 3rd Gen
Lo-Fi Version | Time is now: November 28th, 2024 - 7:58 AM |
