> Cutting Springs, Dropzone not enough!!
post Jun 4, 2005 - 11:18 PM
6gc_driven
Joined Apr 16, '05
From Orlando, FL
hey everybody,
i put some 18'' rims on my car and bought some dropzone springs and installed them hoping that it will drop my car at least 2", but that didnt happen. My car did drop, but only about 1.5 inches, which isnt what i wanted. The car looks "ok" the way it is, but a lil more drop will make a big difference. So i was wandering, will cutting the dropzone spring just a lil bit make a big difference on how the car rides (will it bounce too much or do any weird things)????(sorry if thats a dumb question)
I just dont want to trash those springs and have to buy some other lowering springs, or even some crappy coilovers (which will not give me a good ride when driving)
post Jun 4, 2005 - 11:30 PM
Mike
Joined Oct 22, '02
From Toronto
wait for the springs to settle and it should be down to about 2 inches
post Jun 4, 2005 - 11:52 PM
6gc_driven
Joined Apr 16, '05
From Orlando, FL
yeah..they told me that when i first installed the springs, but i forgot to mention one lil detail...its been over a month since i installed the springs....im pretty sure they have already settled.. any other suggestions?
post Jun 5, 2005 - 12:16 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
chopping springs are for honda dudes. go get some coilovers and some koni yellow adjustabe struts and basically switch the coilover spring rate to about 250-300 in the front cuz they come with around 600 all around and that's why it's so bouny. and about 200-250 in the rear and you'll be set. it's just like having a full coilver setup...ya the real kind!!
post Jun 5, 2005 - 3:36 PM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(rjbibeau @ Jun 5, 2005 - 10:16 AM)
[right][snapback]295244[/snapback][/right]
he has coil overs..
have you tried just using the springs and not the sleeve and rings?
your last resort should be cutting the coils.
post Jun 5, 2005 - 11:11 PM
6gc_driven
Joined Apr 16, '05
From Orlando, FL
i really dont want to buy coil overs, then buying the springs would just be a waste of my money...
yo hanyo, wat u mean just using the spring, not the sleeve and rings?? (sorry man, im not familiar with all these technical terms)
post Jun 6, 2005 - 2:13 PM
QUOTE(Hanyo @ Jun 5, 2005 - 3:36 PM)
he has coil overs..
[right][snapback]295270[/snapback][/right]
hanyo your dork
he has SPRINGS NOT COILS
just springs
and don't tell people cutting springs is a resort at all
cutting = increditably UNSAFE and DANGEROUS
now
you bought dropzone and all they are stated to is like 1.5" anyways so if you wanted 2" why'd you buy them?
so you've already wasted your money...........
if you want 2" the only way to get there is to get a set of coilovers
ground control or arospeed or tien is how you do it
this is were the "sleeve and rings" come in
coilovers are mounted by sliding a "sleeve" with threads on it
over your strut
then there are 2 PERCHES that spin on this sleeve moving up and down changing ride hight
that is how coilovers work
you have springs which don't have them
IMO go trash the dropzone
and get a set of coilovers with either kyb gr2 struts or koni yellow struts
This post has been edited by playr158: Jun 6, 2005 - 2:14 PM
post Jun 6, 2005 - 9:01 PM
6gc_driven
Joined Apr 16, '05
From Orlando, FL
well..ur right on that..i guess i did trash my money when i bought the springs in the first place...i just figured it will drop at 2" cause it said "drop range from "1.5-2.5""...but oh well, my mistake...
i guess ima have to go buy some coil overs..
thnx for the advice tho...
post Jun 7, 2005 - 3:46 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
I cut springs(stock) in the past with no problems what so ever. Wasn't on my celica though.
post Jun 9, 2005 - 8:17 PM
Sev408
Joined Dec 4, '03
dont cut your springs sell them here and buy these:
Tanabe DF210 Lowering Springs like $170 and drops 2in. to 2.5in
user posted image hows it taste motha f*cka
Lo-Fi Version Time is now: November 25th, 2024 - 12:10 AM
