4age harness, 7age |
Jun 6, 2005 - 11:59 AM |
Enthusiast Joined Feb 15, '05 From Frederick, Maryland Currently Offline Reputation: 8 (75%) |
i am very close to getting all the parts for a 7age but need to know if the wiring harness will be the same for the 7afe/7age/4age therefore only needing to change the ecu and cylinder head (and components).
Jun 6, 2005 - 12:01 PM |
your goin to need a 4age harness, head, sensors, ecu
Jun 6, 2005 - 12:04 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
QUOTE(yungazzdriver @ Jun 6, 2005 - 9:59 AM) i am very close to getting all the parts for a 7age but need to know if the wiring harness will be the same for the 7afe/7age/4age therefore only needing to change the ecu and cylinder head (and components). [right][snapback]295466[/snapback][/right] you're going to need a full 4age harness to splice into your existing mainly just the engine harness and 4age with a piggy back for my 7agte i went standalone way less of a headach -------------------- yea your 3sgte is cool but ill stick to my 7agte
Jun 6, 2005 - 6:54 PM |
and also wanted to know what would i do about the alternator?
how will it go on? |
Jun 7, 2005 - 12:50 AM |
QUOTE(yungazzdriver @ Jun 6, 2005 - 11:54 PM) and also wanted to know what would i do about the alternator? how will it go on? [right][snapback]295632[/snapback][/right] Charging system is connected to the body harness... not the engine. You will need the engine harness, ECU, main sensors, injectors, manifolds, head, basically the top-end. Wiring will be slightly tricky, cause you're gonna need to splice into the dash/body harness too... -------------------- "It's ok to be naked girl... I'm an artist!"
Jun 7, 2005 - 9:07 AM |
QUOTE(Kwanza26 @ Jun 6, 2005 - 10:50 PM) QUOTE(yungazzdriver @ Jun 6, 2005 - 11:54 PM) and also wanted to know what would i do about the alternator? how will it go on? [right][snapback]295632[/snapback][/right] Charging system is connected to the body harness... not the engine. You will need the engine harness, ECU, main sensors, injectors, manifolds, head, basically the top-end. Wiring will be slightly tricky, cause you're gonna need to splice into the dash/body harness too... [right][snapback]295761[/snapback][/right] this is why i went standalone well one of the reasons but for your application its works good -------------------- yea your 3sgte is cool but ill stick to my 7agte
Jun 7, 2005 - 8:57 PM |
dankz
Lo-Fi Version | Time is now: November 28th, 2024 - 9:52 PM |
