> Turbo and CHECK VALVES
post Jun 6, 2005 - 1:12 PM
ok so what up with these "check valves"
what are they?
where do they go?
what do i need them for?
can i do sumthing different then use them?
post Jun 6, 2005 - 1:23 PM
a check valve is a valve that lets air pass one way but not the other. it has nothing to do with a turbo or none turbo car.
post Jun 6, 2005 - 1:25 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
There are many different sizes and shapes of check valves. Basically they just restrict air flow one way, and allow it to freely pass the other.
They can be used in many different situations
post Jun 6, 2005 - 1:49 PM
i'm doin it on a 7afte
how does it play into the 7afte
setup and why
This post has been edited by playr158: Jun 6, 2005 - 2:16 PM
post Jun 6, 2005 - 3:01 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
If you dont know how or why, why are you doing it?
post Jun 6, 2005 - 3:11 PM
nik
Joined Sep 30, '02
i sent a pic to coomer of my check valves for my old 7afte he hasnt got them up yet
they bleed off pressure between your manifold and map sensor so the map doesn't see your boosting thats what they do
post Jun 6, 2005 - 3:16 PM
erics1one
Joined Aug 27, '04
on a NA setup they're used between the crankcase vent -> intake VAC line so that the crankcase isn't pressurized.
Know you talkin bout turbo setups....but thats just something else they're used for.
post Jun 6, 2005 - 5:34 PM
bowdown.gif i have forged jdm check valves that have been custom ported in japan bowdown.gif
This post has been edited by lagos: Jun 6, 2005 - 5:36 PM
post Jun 7, 2005 - 10:24 AM
hey NIK if you have a picture of the check valves please post it here
cause at coomers rate of speed we won't see them till maybe late next year
post Jun 7, 2005 - 11:20 AM
nik
Joined Sep 30, '02
QUOTE(playr158 @ Jun 7, 2005 - 8:24 AM)
[right][snapback]295843[/snapback][/right]
here you go
post Jun 7, 2005 - 11:26 AM
now can you explain that lol
it just looks ummm interesting?
post Jun 7, 2005 - 12:55 PM
nik
Joined Sep 30, '02
QUOTE(nik @ Jun 7, 2005 - 9:20 AM)
[right][snapback]295866[/snapback][/right]
QUOTE(playr158 @ Jun 7, 2005 - 9:26 AM)
[right][snapback]295870[/snapback][/right]
well you plug one end into the map sensor and the other in the Intake manifold replacing your old line that went from the manifold to the map wink.gif or what did you want to know?
post Jun 7, 2005 - 1:24 PM
well thats all haha
unless you have an installed pic?
cause i've gone through your how to
and didn't really see/hear much about them
This post has been edited by playr158: Jun 7, 2005 - 1:27 PM
post Jun 7, 2005 - 3:04 PM
nik
Joined Sep 30, '02
QUOTE(nik @ Jun 6, 2005 - 1:11 PM)
[right][snapback]295558[/snapback][/right]
as i explained further up
"they bleed off pressure between your manifold and map sensor so the map doesn't see your boosting thats what they do" NIK
go look under your hood see the map sensor and the vac tubing coming out of the bottom and going to the intake manifold ..... now see the pic i posted you pull off your tubing and connect the check valve system and your done dude you should know n/a map sensors dont like boost so this is how you fool them or you can hardwire in a 1 or 2 bar map sensor but you have to make sure the ecu can under stand it go out a buy ..... i can remeber the of that boosting book anyways go read up it will probably answer some of your questions you keep asking
post Jun 7, 2005 - 3:37 PM
yea max boost....
thanks
Lo-Fi Version Time is now: December 1st, 2024 - 3:33 PM
