> 5sfe compression
post Jun 7, 2005 - 10:49 PM
fastgt
Joined Feb 13, '03
From California
what numbers should i get across the four cylinders?
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
post Jun 8, 2005 - 12:06 AM
Compression pressure:
4A–FE 1,320 kPa (13.5 kgf/cm2, 191 psi) or more
3S–GTE 1,128 kPa (11.5 kgf/cm2, 164 psi)
or more
5S–FE 1,226 kPa (12.5 kgf/cm2, 178 psi)
or more
Minimum pressure:
4A–FE and 5S–FE
981 kPa (10.0 kgf /cm2, 142 psi )
3S–GTE 883 kPa (9.0 kgf/cm2, 128 psi)
Difference between each cylinder:
98 kPa (1.0 kgf/cm2, 14 psi) or less
post Jun 8, 2005 - 12:13 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
good info i needed that too thanks lagos
post Jun 8, 2005 - 12:15 AM
check out the online BGBs at celicatech. i just copied and pased from there smile.gif
post Jun 8, 2005 - 4:39 AM
fastgt
Joined Feb 13, '03
From California
youre awesome lagos
Lo-Fi Version Time is now: December 1st, 2024 - 3:56 AM
