> Engine problems, bad gas miles
post Jun 8, 2005 - 4:42 PM
gtcelica94
Joined Apr 4, '04
im running way to rich i am getting about 18 mpg on my 94 gt. my car coldnt pass inspection either so im guessing im running rich as hell.i dont even know where to start . any suggestions would gratefull
post Jun 8, 2005 - 6:37 PM
gt_driFFter
Joined Nov 29, '04
QUOTE(gtcelica94 @ Jun 8, 2005 - 4:42 PM)
[right][snapback]296494[/snapback][/right]
Start with the cheapest stuff first (better than replacing something expensive and it not fixing it).
-Spark Plug
-Wires
-Rotor button
-Distributor Cap
-Air Filter (not likely, but could be a contributor)
-O2 sensor (generally not very cheap but again, could be a contributor to the problem)
-Josh
This post has been edited by gt_driFFter: Jun 8, 2005 - 6:38 PM
post Jun 9, 2005 - 12:43 AM
QUOTE(gt_driFFter @ Jun 8, 2005 - 6:37 PM)
-Spark Plug
-Wires
-Rotor button
-Distributor Cap
-Josh
[right][snapback]296542[/snapback][/right]
I agree with trying the small stuff first, but with it as bad as you say, I would almost guarantee it's one or both of the o2 sensors. First check to see if they are connected properly, that could be an easy fix. do a search for "sensor" or "mileage" I know there have been quite a few topics about this...
post Jun 9, 2005 - 4:56 AM
yup dustin, definetly sounds like a 02 sensor to me...also make sure your wires car and rotor are in good working order, and that your air and fuel filter are clean.
post Jun 9, 2005 - 8:21 AM
gtcelica94
Joined Apr 4, '04
i remmber along time ago some one told me air temp sesor. back when this this problem started, but i dont have a cel light on
post Jun 11, 2005 - 11:41 AM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
also i remember running some fuel injector cleaner and seeing a small dif. but how bad it is for you sounds more like O2 sensor(s) are about to go capoot.
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jun 11, 2005 - 5:25 PM
that bad.
Lo-Fi Version Time is now: January 11th, 2025 - 11:00 AM
