> WTF! you think i would have learned., another turbo bites the dust.
post Jun 8, 2005 - 8:29 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
So im driving along and i realize im at 4k with no boost.... im like uhh. so i rev it and i hear snap crackle pop and then boost to 5psi then bamm smoke oil yeah. it was fun. so here are my options
by a new turbo.
go back to NA
but i said screw buying a new turbo since then i wont have the money for piston rods ect..
so no point in blowing the motor up. (the motor is fine) i cant belive it.
but i came to realize that this motor isnt really ment for boost unless u build it proper IE pistons rods ect. if i bought a larger more effcient turbo im sure this wouldnt of happend. but who knows that if i had a good turbo thqat my motor would have been the weakest link.
so im going NA till i can afford a 3sgte swap.
thats right im going to the darkside tongue.gif haha jp
but no really it will take time and money but i love this car to much to give up on it.
so yeah... RIP 5sfte
i hate this kid. mocking me.
This post has been edited by x_itchy_b_x: Jun 8, 2005 - 8:31 PM
post Jun 8, 2005 - 8:37 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
lmao@kid
sorry about your...lack of learning?
GL w/ all
post Jun 8, 2005 - 9:06 PM
wow, the 5s is ok? did u check compression on the motor?
i really dont know what you 5s and 7a guys are doing wrong. ive talked to a lot of guys that are on their 2nd or 3rd turbo. meanwhile i have the same one that has lasted for over 60,000miles. you must not have the correct size oil or coolant lines going to it.
edit: and fyi, turbo lasted so long and the car has never had a turbo timer installed!
This post has been edited by lagos: Jun 8, 2005 - 9:13 PM
post Jun 8, 2005 - 9:13 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
nah the turbo wasnt effcient like manny said. it was to small of a trim i basicly over spolled it and cooked the barings
post Jun 8, 2005 - 9:14 PM
yes manny was right.... but how did your last ct26 die then?
post Jun 8, 2005 - 9:19 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
same thing. old ct26 supra one ment for 8 psi . i ran 13. killed it quick and it was from an 88 so i mean it was old and i payed 75 bucks or sumthing stupid like that.
post Jun 8, 2005 - 9:27 PM
i would talk to manny to make sure your coolant or oil lines are not to big/small. its very very common for custom turbo guy to kill turbos left and right ... somethine about thes supply lines that must be casing the tubos to die (my opinion)
anyway, it will be great to see you join the 3sgte club!
post Jun 9, 2005 - 4:51 AM
yea itchy, it was just a matter of time with that t3...you would have been MUCH better off with a '26 twin entry..
sorry to hear about the death... wink.gif now you just get to build it bigger, and better
This post has been edited by presure2: Jun 9, 2005 - 4:52 AM
post Jun 9, 2005 - 7:04 AM
carlosfandango
Joined Mar 31, '05
From Northern England.
i was under the impression that the block internals are lightweight by design allready, and this helps quick rpm response and aids, in addition to the cam design, a smooth torque curve in the power band right up to peak power.
using a turbo just makes excessive heat and not just charge temps - coolant and oil will absorb heat too.
i'd like to know more about FE and FI..
see my gallery at http://www.gt4oc.net/owners/owners_page.php?owner=2938
90 GT4 JDM 270bhp
89 GT4 UK Carlos Sainz Engine and Tranny - project
87 GT Convertible, 3SGE powered with nitrous, 205bhp.
post Jun 9, 2005 - 11:34 AM
erics1one
Joined Aug 27, '04
From Orange County, CA
Mannys been preachin the -3 oil feed and -12 oil drain sizes for quite some time. I hope its been beatin into everyones head by now. As long as you use these sizes, and your drain line isn't makin nasty curves, you should be okay in that department.
Itchy...were both your turbos used? Or did you rebuild one? Might have just been unlucky and got them when they're at the end of their life.
post Jun 9, 2005 - 5:24 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i redid my line with the new turbo with those lines. that wasnt the problem. after taking apart the turbo the retard who i bought it off had an o ring peice of metal backwards. and scored the back of the impeller causing it tocreat heat and friction. im getting to know the insides of turbos now lol
post Jun 9, 2005 - 5:29 PM
erics1one
Joined Aug 27, '04
Well sounds like you've just had bad luck with turbo conditions. If all you need is a freshly rebuilt CT26, I'll have one for sale pretty soon, had an extra layin around the garage and am rebuilding it now. Let me know
http://www.6gc.net/forums/index.php?act=ST&f=8&t=25851
This post has been edited by erics1one: Jun 15, 2005 - 9:58 PM
post Jun 9, 2005 - 7:38 PM
946thGenGT
Joined Oct 4, '04
Well if you are going back to NA and plan on unloading your turbo related parts I'd probably be interested in buying some/all.
post Jun 10, 2005 - 1:51 AM
erics1one
Joined Aug 27, '04
nope, just getting rid of the extra turbo
post Jun 10, 2005 - 7:15 AM
Illyont
Joined Apr 8, '05
From Norway
QUOTE(erics1one @ Jun 10, 2005 - 1:51 AM)
[right][snapback]297189[/snapback][/right]
Lo-Fi Version Time is now: February 22nd, 2025 - 8:40 PM
