Enthusiast ![]() ![]() Joined Sep 26, '04 From Sacramento, California Currently Offline Reputation: 4 (100%) ![]() |
On the website it says it requires hood pins, does it really? Does any one have this hood on their car? Thanks
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) ![]() |
it does not
they say hood pins to make it safe for speeds over 150, although since it uses stock latch it should be fine as is anyways. it's like "off road use only" type of deal -------------------- ![]() |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) ![]() |
ya, i have the c-one hood, i've hit 110 with no problem. Most the time you wont need 2 drive that fast, so it should be good. Hood pins do look kinda cool, but kinda ricey to me, especially if there not nessasary
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... ![]() |
Enthusiast ![]() ![]() ![]() Joined Apr 8, '05 From Norway Currently Offline Reputation: 0 (0%) ![]() |
Can someone post a picture of a hood with pins? I'm not sure if I know what those pins are.. That is, I think I know, but then again I could be wrong.
i have hood pins!
QUOTE(playr158 @ Jun 10, 2005 - 10:27 AM) http://photobucket.com/albums/y174/srplayr...t=newest008.jpg [right][snapback]297290[/snapback][/right] How does those work? Are they like a two piece assembly that goes one below and one on top of the hood.. And then they are connected like this: CODE | ---|--- | | | | | The -- being the hood.. and the middle line being like a pin, that goes through the hood and down into the other part of the "hood pins" below the hood.. Holding it in place. Why can't you just use the stock assembly? Move it from a stock hood and install on the aftermarket hood. This post has been edited by Illyont: Jun 12, 2005 - 10:39 AM -------------------- ![]() |
QUOTE(Illyont @ Jun 12, 2005 - 11:38 AM) QUOTE(playr158 @ Jun 10, 2005 - 10:27 AM) http://photobucket.com/albums/y174/srplayr...t=newest008.jpg [right][snapback]297290[/snapback][/right] How does those work? Are they like a two piece assembly that goes one below and one on top of the hood.. And then they are connected like this: CODE | ---|--- | | | | | The -- being the hood.. and the middle line being like a pin, that goes through the hood and down into the other part of the "hood pins" below the hood.. Holding it in place. Why can't you just use the stock assembly? Move it from a stock hood and install on the aftermarket hood. [right][snapback]297899[/snapback][/right] you can use the stock assembly, hood pins are not required. I say leave em off, I think it looks better clean, and I dont like 2 drill into things. -------------------- To live, is to suffer
nope
its basically a bolt bolted to the frame of the car that comes out through the hood then the pin is attached to the hood and slides into the bolt take sum time look online if you see a picture of a hood pin kit you'll understand |
nope
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) ![]() |
hood pins are fugo, leave em on cars that NEED them only, most CF hoods, you don't.
Lo-Fi Version | Time is now: February 25th, 2025 - 3:35 AM |
