Enthusiast ![]() Joined Oct 15, '04 From Muskegon Currently Offline Reputation: 0 (0%) ![]() |
Can you rotate parts of the turbo like the housing and stuff? cuz i cant fit it in my car. the waste gate sticks out to far. So i need to flip that center part of the turbo where it connects to the manifold. (what ever that part is called). So i was thinking of rotating them things but i dont know if i can do it or not.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) ![]() |
Wouldn't the blades of the turbo be facing the wrong way?
Enthusiast ![]() ![]() ![]() Joined Jul 27, '04 From phoenix az Currently Offline Reputation: 0 (0%) ![]() |
are you talkin about clocking the outlite side of the turbo?
like if i wanted to flip the center part aroud without movind the blades. could i just rotate it
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) ![]() |
rotate it in which direction?? if you mean clocking then yes. but that refers to rotating the intake side. if you rotate the middle, chances are u also need to move the other parts (downpipe, flange, exhaust manifold) to go with the new position.
Lo-Fi Version | Time is now: February 22nd, 2025 - 3:09 AM |
