clicking noise for the engine!!, got any clue what it is?? |
Jun 13, 2005 - 12:55 PM |
Enthusiast Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) |
well after boosting 10lbs one night i started to hear this clicking noise coming from the engine. any ideas what it is...im have no clue what it is..its not the fan hitting anything,or the turbo..have no clue its not the engine(i think) either it only happens when i drive the car..reving and everthing fine. help
Jun 13, 2005 - 12:59 PM |
Enthusiast Joined Feb 26, '04 Currently Offline Reputation: 0 (0%) |
if it only happens when ure driving around, it might be not be ur engine, maybe cv joint.. does it happen when u turn?
Jun 13, 2005 - 4:12 PM |
Enthusiast Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
When is it... revving, when boost is on/off/between, etc?
My bearings all need replaced, main, rods, etc... I have a bit of rod knock.. A friend/racer/mechanic suggested this, and reasoned it because when horsepower goes up, pressure goes up, but the bearings are still the same.. -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Jun 15, 2005 - 9:09 AM |
no it only happens when i drive..it doesn't happen when i turn corners or boost..it cant be my cv i cheked them there all good.
Jun 15, 2005 - 10:49 AM |
weak vlave spring? and when u boost it starts to float so u dont hear it?
Jun 17, 2005 - 12:37 PM |
you might be right what should i do then..where could i get stronger ones..
Lo-Fi Version | Time is now: January 12th, 2025 - 7:38 AM |
