> Sub Door Question, Redoing the Premium Audio package
post Jun 14, 2005 - 2:10 PM
jbcustom
Joined Oct 25, '04
From Los Angeles
So I decided to finally go full aftermarket with the speakers in my celica. problem is that I have the premium audio package. I have a total of 8 speakers in my car.
These include:
8" paper woofers in the door
4"midrange components in the door
3/4" tweeters in the door
6x9 in the rear.
I have already purchased a Pioneer 8600MP for the HU. And pioneer's 3 way 6x9 and 4" speaker. Would any one have any recommendations on subs that will fit the door? I want sound thats loud and crisp. I was going to go with Polk Momo 8" subs. Any further suggestions?
I am going to make sure to get pictures of the project. I plan on moving the battery to the back. I have to do all custom wiring because of a funky "not standard" premium amp (the wiring harness for the 89+ toyotas doesnt match). Any comments would be more than helpful.
post Jun 14, 2005 - 2:19 PM
JL also has a great 8"
have you thought about an aftermarket amp?
This post has been edited by playr158: Jun 14, 2005 - 2:19 PM
post Jun 14, 2005 - 2:31 PM
jbcustom
Joined Oct 25, '04
From Los Angeles
QUOTE(playr158 @ Jun 14, 2005 - 7:19 PM)
[right][snapback]299040[/snapback][/right]
Yes thought about an amp. Im not sure which model yet, but I know I want to wire the 6x9's and the 8's up. No way that the HU will power them to my liking. Does any 8" woofer fit the door? Depth and vibration a problem?
post Jun 14, 2005 - 3:52 PM
runriot95
Joined Dec 1, '02
From Pittsburgh, PA
If you want to go with an 8 inch sub ( and not an 8 inch woofer, which I think is what the factory is ), I would definitely recommend an aftermarket amp.
How about this scenario: a 4 ch amp to power the subs and 6x9s, and your head unit to power the 4s and the tweets?
As far as the depth question, our doors DO have a decent amount of depth. The problem is that if you want to use the factory mount for the speaker, you don't have much room for any size magnet on the speaker. In other words, the hole where the magnet would poke through is not very big. If you're willing to create your own speaker mount and maybe do a little cutting into the door - then YES, there's room.
One last note on the subs: If you are buying TRUE subs, and not just woofers, then make sure you get something that is designed for infinite baffle and NOT for an enclosure. Unfortunately, most subs are designed for enclosures of some sort. If you don't, you probably won't be happy with the results.
post Jun 14, 2005 - 4:07 PM
you can always mount inverted do to lack of inner door space
post Jun 14, 2005 - 4:13 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
Blaupunkt has a slimline speaker and probably a sub.. gotta check on enclosure design
post Jun 14, 2005 - 4:52 PM
jbcustom
Joined Oct 25, '04
From Los Angeles
QUOTE(runriot95 @ Jun 14, 2005 - 8:52 PM)
[right][snapback]299094[/snapback][/right]
what exactly is the difference between "subwoofer" and "woofer"? I'll make sure to inquire about infinite baffle.
post Jun 14, 2005 - 5:59 PM
Scarrell
Joined Nov 8, '04
From Carmi, Illinois
subwoofers play lower, and woofers are mid ranges that play midrange frequencies... if you want the best sound get some components... you will want to power your woofers and speakers with an amp... id power everything off the amp and the 6x9"s off the deck.. actually...if you want an 8" subwoofer in your door, it needs to be free air capable... Kicker and JL have some of these that can suit your needs.. anyway as i said... power the Speakers off the deck, and the component set and sub/woofers off the amp... what kind of components do you have anyways?
i want a stereo so loud, it blows womens clothes off.
TrickedOutS2000: I just opened a box that arrived on my doorstep cuz i thought it was my H.U.
TrickedOutS2000: it was a vibrator my dad bought
scarr3ll: WHAT THE ****?!?11
TrickedOutS2000: yeh
TrickedOutS2000: for my mom im guessing
TrickedOutS2000: but yeah
TrickedOutS2000: eww
TrickedOutS2000: so
TrickedOutS2000: ****ing
TrickedOutS2000: wrong
My Cardomain Page.
Car Audio Central
msn: jared_s_c@hotmail.com
aim: Scarr3ll
post Jun 14, 2005 - 6:51 PM
runriot95
Joined Dec 1, '02
From Pittsburgh, PA
QUOTE(Scarrell @ Jun 14, 2005 - 3:59 PM)
[right][snapback]299140[/snapback][/right]
Yeah, what he said.
post Jun 14, 2005 - 6:52 PM
celicagurl152003
Joined Oct 12, '04
From Montgomery, AL
8" subs in the door won't give you much room trust me i know.....user posted image
post Jun 16, 2005 - 2:13 AM
red94celicagt
Joined Jan 28, '05
From Cincinnati, Ohio
i say defffffs do that. Pointikng the subs inward will give them more "bump" as heard mostly in techno. Instead of sounding muddy they will be more crisp and accurate...
Not to mention practicality...do you really want to do that kind of custom cutting? so much easier to mount em backwards
Speeding is only Illegal...
If you Get Caught
post Jun 16, 2005 - 1:51 PM
jbcustom
Joined Oct 25, '04
From Los Angeles
I'm actually going to go with a mid-bass driver in the doors. I'll have to figure out a way to put in two tens with out sacrificing any of the trunk space, which I need. If any of you have suggestions on good locations, with out going too custom, it would be awesome. PICS?
post Jun 19, 2005 - 11:12 AM
Cutrara
Joined May 6, '05
From PA
One word: Fiberglass
post Jun 19, 2005 - 9:46 PM
Abraxis64
Joined Mar 4, '05
From hawaii
QUOTE(red94celicagt @ Jun 16, 2005 - 2:13 AM)
[right][snapback]299839[/snapback][/right]
invert mounting a subwoofer will not change the sound of the driver one bit (ie, it won't give them more "bump) but what it will do is allow the possibility of more audible motor noise (anything from tinsel lead slap to hitting the backplate)...main benefit of invert mounting a sub is looks--no more, no less...
peace
Lo-Fi Version Time is now: January 12th, 2026 - 7:15 PM
