Vacume lines on CAI, dunno where they go |
Jun 14, 2005 - 3:02 PM |
Enthusiast Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) |
Ok, so on the intake i made/installed, theres a pice coming out of the pipe for a vacume line or something, and i have no clue of where to put it to/what its for or if i should just seal it. I know that on some cars you have to use vacume lines such as on an RSX, but i dunno about this one. Ill go take a picture of the intake and tell me where u think i should run it to/if i should.
This post has been edited by Valo666: Jun 14, 2005 - 3:12 PM |
Jun 14, 2005 - 3:18 PM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Isn't that for the o2 sensor?!
-------------------- JDM Powerplant installed, BPU coming very soon!
Jun 14, 2005 - 3:21 PM |
Enthusiast Joined May 7, '04 From Leeuwarden, Netherlands Currently Offline Reputation: 0 (0%) |
Just seal it. Now it is sucking in false air. it serves no purpose.
It's prolly ''one size fits all" CAI, so its there for cars who do need it. This post has been edited by Silvan: Jun 14, 2005 - 3:23 PM |
done and done..im either gonna weld it or just pop a self tapping screw in it
Jun 14, 2005 - 3:24 PM |
difficult to weld. its aluminium isn't it?
Jun 14, 2005 - 3:25 PM |
yea...i can weld aluminum..i welded a full aluminum robot frame for my schools robotics team
Jun 14, 2005 - 3:34 PM |
Enthusiast Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
Or put a rubber cap on it to seal it or something. It's for PCV, I believe.
Jun 14, 2005 - 4:42 PM |
Enthusiast Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
Did you take anything off your stock intake?
I'm guessing you have access to a TIG welder? -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Jun 14, 2005 - 5:17 PM |
tig and mig...but mostly mig...its harder 2 weld with but i can get access to it easily. but only thing i took off my stock intake box was a few clips, and the grommit for the sensor..it doenst fit in right right now just because the hole has to be bigger. im probably gonna pop one of the shift knob inserts in off my new knob and just apoxie it in with some 5 min apoxie.
This post has been edited by Valo666: Jun 14, 2005 - 5:19 PM |
Jun 14, 2005 - 6:26 PM |
Enthusiast Joined Aug 27, '04 From Orange County, CA Currently Offline Reputation: 0 (0%) |
Its for your Crankcase Vent, coming out the side of your valve cover.
The Injen intakes come with the port on the intake and also include a vac line, so I imagine itd be better to have it. -------------------- |
Jun 14, 2005 - 11:58 PM |
the yellow is the hose that u need, find that and use the blue directions. and you dont have a cai, you have a very short ram intake setup there...a cai is far from engine.
This post has been edited by LewFX: Jun 14, 2005 - 11:59 PM -------------------- |
Jun 15, 2005 - 12:29 AM |
Enthusiast Joined Nov 17, '03 From New York Currently Offline Reputation: 1 (100%) |
QUOTE(LewFX @ Jun 15, 2005 - 4:58 AM) the yellow is the hose that u need, find that and use the blue directions. and you dont have a cai, you have a very short ram intake setup there...a cai is far from engine. [right][snapback]299247[/snapback][/right] If you run it where the blue is, then what do you do with the other end of the yellow, which is the opposie end of the valve cover? Plug it or get one of those little filters? This post has been edited by TRD6GC: Jun 15, 2005 - 12:30 AM |
Jun 15, 2005 - 9:17 AM |
the end of the hose looks to be jungled in, hook it up to the both blue ends.
http://www.lewfx.com/celica/DSC00168.JPG check out where i put my hose., same idea but yours is farther away. -------------------- |
Jun 15, 2005 - 8:20 PM |
Enthusiast Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) |
do we have to do this with an ST? what do you do with the top part of the yellow that is disconnected?
Jun 15, 2005 - 8:34 PM |
its loose in the bay somewhere, find it and plug it in
Jun 15, 2005 - 11:10 PM |
im sorry i meant where the "yellow" hose used to go in, by the throttle body. the hose is disconnected from there and hooked up to the inteake, right? what do you do with the spot that the hose was disconnected from?
Jun 15, 2005 - 11:41 PM |
take the hose and follow the blue path. the yellow was just showing you where the hose was before. use the blue diagram!!!!!!
Jun 15, 2005 - 11:53 PM |
lol, i know!!! either im retarded and you already explained it, or i am just being unclear.
Jun 15, 2005 - 11:58 PM |
on my injen there were 2 nipples, check out the pic.
This post has been edited by LewFX: Jun 16, 2005 - 12:04 AM -------------------- |
Jun 16, 2005 - 12:06 AM |
ok so will i be fine if i just blocked off the 1 nipple on my intake? it was on my brother's car, but then he sold it. i cut the intake to fit, but wasnt sure what to do with the nipple besides just block it off.
Lo-Fi Version | Time is now: November 26th, 2024 - 8:22 AM |
