I need serious help., 94' GT stock instrument cluster |
Apr 19, 2003 - 4:44 AM |
Enthusiast Joined Oct 19, '02 From Riverside,Ca. Currently Offline Reputation: 0 (0%) |
I was wondering if anyone knew of a good website that sells celica parts online? I mean the hard to find parts.. cause I need the stock guage cluster thing. my speedometer and RPM needles do not work. any help would be apprieciated. thank you.
Apr 19, 2003 - 6:26 AM |
try here tap recycleing
13.6@108MPH, 5SFTE Powered |
Apr 19, 2003 - 9:42 AM |
Enthusiast Joined Nov 20, '02 From Chicago to Boston and back to Chicago Currently Offline Reputation: 0 (0%) |
This is your 1st post since October?
Apr 19, 2003 - 10:35 PM |
Enthusiast Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
,,,Or maybe car-parts.com car-parts.com
This post has been edited by 97GTinKC: Apr 19, 2003 - 10:36 PM |
Apr 19, 2003 - 10:41 PM |
Enthusiast Joined Apr 18, '03 From philadelphia Currently Offline Reputation: 0 (0%) |
Hi there,
I had the same problem happen to me after I installed my white-face gauges. If I recall correctly you can purchase just the circuit board that is screwed onto the back of the gauge cluster. I bought mine from the dealer and it didnt cost me too much. Really easy to install as well. It also will keep your mileage the same, which is a problem you will run into if you switch out clusters. If you switch out the cluster for one with lower miles and try to sell the car it will come up as an odometer discrepancy and you car will no longer have a clear title. Hope that helps matt |
Apr 21, 2003 - 3:42 AM |
Thanks for your help everyone, im glad people replied.
Apr 21, 2003 - 6:46 AM |
Enthusiast Joined Oct 27, '02 From Barbados Currently Offline Reputation: 0 (0%) |
What you can do is to go aftermarket.
You can replace your rev and speed meter with an Apexi Rev/Speed Meter. You can then use 52mm gauges from greddy, blitz, hks to replace other small gauge lie temperature. -------------------- West_Minist
Hydra EMS Dealer & Tuner Subaru ECUFlash Tuner http://www.socob.bb http://xtremeracingtuning.com Viciously Tuned, Driven Hard |
Lo-Fi Version | Time is now: November 28th, 2024 - 1:21 PM |
