> injectors, can i use these injectors
post Jun 15, 2005 - 1:52 PM
dans_st
Joined May 24, '03
From Andrews TX
i was wondering if anyone knew if i could use DSM injectors on my 7AFTE I have alot of friends that have ALOT of 450 & 550cc low-inpedence DSM injectors and I have heard that you can switch the harnesses but as far as the high to low inpedence there was a resistor box or something you could use?
Any help would be appreciated.
if there is no possible way that I can use thesewhat can i source some injectors off of?
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Jun 15, 2005 - 1:58 PM
nope you need high inpedence
post Jun 15, 2005 - 2:04 PM
nik
Joined Sep 30, '02
QUOTE(dans_st @ Jun 15, 2005 - 11:52 AM)
[right][snapback]299501[/snapback][/right]
go check www.club4ag.com
they were talking about using dsm injectors on a 4age and sodering a resister in to fix the high low issue but from what i read one has them and he said they fit but you have to mod the harness
post Jun 25, 2005 - 4:27 PM
dans_st
Joined May 24, '03
From Andrews TX
I checked all of 4ag's forum and couldn't find a thingon it. does anyone know the title or topic that this was under. I started a topinc in the forums on www.club4ag.com and haven't seen a single reply. I need these on my car bad and my friend has about four sets of 450cc & 550cc RC engineering injectors for his DSM.
post Jun 25, 2005 - 5:10 PM
edo17982
Joined Dec 21, '02
From Italy
You can use Ford Probe turbo injectors if u find them. I don't remember the exact rate but between 400-500 cc
They fit and are high impedance with same connector as 7afe injectors smile.gif
Lo-Fi Version Time is now: November 28th, 2024 - 5:43 PM
