> Can someone please help me verify, about 3sgte swap tranny issue
post Jun 16, 2005 - 9:03 AM
Aaagogo
Joined Jun 16, '05
From Daytona Beach, FL
Hi guys... been reading so much that my head hurts...
I'm on toyotanation, same nick, and i have been lurking here for a while cause i'm doing my engine swap soon and heard from TN that there are tons of valuable information here.
ok, from all that i've read and gathered for the 3sgte swap onto a 6th gen celica.
the 2 avail trannies that are options are;
the E153 from the V6 camry or solara &
the one from the mr2 turbo tranny,
the problem with the mr2 tranny is that something is too short and i'll have to get something from the V6 camry or solara and mate it with the mr2T and make a hybrid
however, that process is only needed if i intended to push for more than 250whp.
Else, if it's just a swap with stock parts and slightly higher than stock boost, the tranny from the V6 camry or solara will blot right on without any modifications and would hold the power that i need. I can't and won't be pushing more that 250, cause mine's a convrt, and the chasis can only hold up to max 300hp before i have to do any body strengthening.
This post has been edited by Aaagogo: Jun 16, 2005 - 12:07 PM
Journal for my 3SGTE swap
Posting and asking qns here for my 3SGTE swap
Regular on ToyotaTuners, no long on TN
Lurker on celictech for my 3SGTE swap
Trying to sell stuff on alltrac.net
Time will tell that it is a mistake to replace the F-14 Tomcat with the F-18 Super Hornet as the carriers first line of defense.
post Jun 16, 2005 - 11:15 AM
there is a pretty good FAQ that explains a lot of it
http://www.celicatech.com/forums/showthread.php?t=81
post Jun 16, 2005 - 12:06 PM
Aaagogo
Joined Jun 16, '05
^ thanx lagos...
most of the info that is written there, i've read them or found it here in 6gc
the only thing i'm unsure about is the tranny part... would my post in the 1st section be right?
post Jun 17, 2005 - 7:47 AM
Aaagogo
Joined Jun 16, '05
Would anyone be able to help me... thanx
post Jun 17, 2005 - 8:20 AM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
you said it right above in your post with the 2 other must common trans used for the swap.
what engine / tranny combo is on your car now?
i am running my 5spd gt tranny and it is holding fine for 2 years now!
post Jun 17, 2005 - 8:21 AM
yea, why not just use the 5s tranny? bolts right up
post Jun 17, 2005 - 9:47 AM
same here, been on the gt tranny. no problems and a headache free install.
post Jun 17, 2005 - 11:23 PM
Aaagogo
Joined Jun 16, '05
^ ok, thanx guys... i will use my GT tranny then,
oh, i'm doin the 3sgte swap into my 96 celica convert.
any sugggetions on the clutch? what clutch are u guys running
post Jun 17, 2005 - 11:30 PM
highly recomend http://specclutch.com/ the stage 2 or 3 clutch for the 3sgte with the splines for the gt tranny .. just call them up and they can make you a disk like this.
post Jun 18, 2005 - 11:16 PM
Aaagogo
Joined Jun 16, '05
Lo-Fi Version Time is now: January 13th, 2025 - 12:38 AM
