Oil, all gone??? |
Oil, all gone??? |
Jun 18, 2005 - 12:03 AM |
Enthusiast Joined Jan 21, '05 From NY Currently Offline Reputation: 0 (0%) |
Just bought the car, checked oil and its lower than lower on the oil stick. The owner whome I trust told me that he changed oil 3500 MI before. Is it normal for celicas to loose that much oil? I looked under the car and there wasn't any oil leaks nor it has any smoke when running.
One more question, the car just hit 90K what should I do? Do I have to change timing belt and fuel pump or can I wait? What else do I need to do? Thank you. -------------------- <<AKA THA RUSSIAN>>
Jun 18, 2005 - 12:51 AM |
Enthusiast Joined Feb 17, '04 Currently Offline Reputation: 0 (0%) |
yea unfortunatley celicas looose more oil than normal well at least mine does also check for tranmission leaks...umm timing belt it depends how it looks id say go ahead and change it ...also chaneg ur struts in teh back and the shocks in teh front
Jun 18, 2005 - 11:05 PM |
QUOTE(latinomasfino @ Jun 18, 2005 - 12:51 AM) yea unfortunatley celicas looose more oil than normal well at least mine does also check for tranmission leaks...umm timing belt it depends how it looks id say go ahead and change it ...also chaneg ur struts in teh back and the shocks in teh front [right][snapback]300855[/snapback][/right] ok, cuz I only had one Toyota before it was 90 corlla and it didn't loose any oil at all. But when I asked the dude about the oil he told me that its fine. So I was a little bit confused because all of the cars I've ever seen or had never lost most of its oil before the change. WIERD!!! -------------------- <<AKA THA RUSSIAN>>
Jul 17, 2005 - 8:10 PM |
Enthusiast Joined Jun 15, '05 From Texas Currently Offline Reputation: 0 (0%) |
[quote=Niskyspy,Jun 18, 2005 - 11:05 PM]
[quote=latinomasfino,Jun 18, 2005 - 12:51 AM]yea unfortunatley celicas looose more oil than normal well at least mine does also check for tranmission leaks...umm timing belt it depends how it looks id say go ahead and change it ...also chaneg ur struts in teh back and the shocks in teh front [right][snapback]300855[/snapback][/right] [/quote] ok, cuz I only had one Toyota before it was 90 corlla and it didn't loose any oil at all. But when I asked the dude about the oil he told me that its fine. So I was a little bit confused because all of the cars I've ever seen or had never lost most of its oil before the change. WIERD!!! [right][snapback]301119[/snapback][/right] [/quote My car also looses oil fast, it seems that im always having to put in another court. My car cant make it to the next oil change unless i want to ride on empty for a while. |
Jul 17, 2005 - 9:36 PM |
That's not good guys. I don't think it's normal...I know that my 4A-GE doesn't burn any oil. And if your oil level isn't registering at all on the dipstick, that's a sign that your motor has permanent damage from oil starvation.
Jul 17, 2005 - 11:45 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
My 7a burns oil just as bad, I have to add about a quart every 2 weeks or so. When I get on it higher than 3.5k rpm's it starts to smoke like a freight train, basically my rings are going. Probably yours are too.
Jul 18, 2005 - 9:03 AM |
yup my 7afe chugs oil like a frat boy chugs beer
Jul 18, 2005 - 9:05 AM |
It says in the celica's owner manual that oil usage is totally normal. Just change the oil and put some 10w40 in it. Keep checking it everytime you fill up for gas and add if you need to. If your using more than 1qrt every 3000miles then your piston rings are probably wore out like mine are...i dont worry about it though, i just keep adding my cheap 99cents/qrt oil every now and then
As far as the timing belt goes its up to you. The engine is non-interference so if it breaks it will do NO damage. The car wont run though so you'll end up stuck somewhere. You will probably just want to get it changed now then get stuck somewhere and have to get it towed. This post has been edited by bufferdan: Jul 18, 2005 - 9:05 AM -------------------- |
Lo-Fi Version | Time is now: November 26th, 2024 - 4:53 PM |
