Gettin Rid of the Seatbelt Light |
Jun 18, 2005 - 11:04 PM |
Enthusiast Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
Just got my new racing harness on my car. Everything is cool except for the annoying seatbelt light. is there any way to kill it?
Jun 18, 2005 - 11:26 PM |
Enthusiast Joined May 23, '04 From Meridian, MS Currently Offline Reputation: 2 (100%) |
you could always take out the gauge panel and pull out the bulb.
Jun 19, 2005 - 8:49 AM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
I'm pretty sure how this works someone correct me if I'm wrong. When you click in the seatbelt, it activates a switch that turns off the light. Look for a wire coming out of the seatbelt connector, on the female side, where it bolts to the center console. Cut the wire and splice the ends together. That gives the instrument panel the illusion that the seatbelt is always connected.
Jun 19, 2005 - 10:09 PM |
Enthusiast Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
Under the seat, a hole in the carpet will show a harness/connector like he said. You can either put a jumper (paper clip, etc) in, and tape over it for a removable option, or you can solder a jumper across the wires, or you could do as cutrara said and close the circuit permanently
-------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Jun 19, 2005 - 10:14 PM |
Enthusiast Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
i'm pretty sure the switch is on the seat belt retractor, i'll get you the color code for that wire so you can easily locate it and bypass it. I got the car in a million peices so i'll experiment with it
-------------------- ----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Jun 20, 2005 - 12:01 PM |
Enthusiast Joined Jun 19, '05 From New York Currently Offline Reputation: 1 (100%) |
ok i put a new seat in mine to.. under the stock seat theres the "alarm" system.. jus take the seat belt clip fron the stock seat and put it on the aftermarket.. then connect that clip again that was under the seat, thats what i did and everything works good.. idk abour harneses yet though
Jun 21, 2005 - 9:21 AM |
QUOTE(K-ESD @ Jun 19, 2005 - 11:14 PM) i'm pretty sure the switch is on the seat belt retractor, i'll get you the color code for that wire so you can easily locate it and bypass it. I got the car in a million peices so i'll experiment with it [right][snapback]301511[/snapback][/right] I was wrong, this is what i was looking at It has nothing to do with the seatbelt light This is the seatbelt light wire (under driver seat) (sorry for the poor image quality, this digicam is old) -------------------- ----------------------6GC's FIRST V6----------------------
Jun 21, 2005 - 9:22 AM |
wass that not what we said hahaa
Jun 21, 2005 - 10:18 AM |
Its not on the retractor simply because some people are all different sizes.
Jun 21, 2005 - 10:35 AM |
I know thats what everyone said, i just felt so bad for saying something wrong i had to add some pictures to make me feel better
QUOTE(Supersprynt @ Jun 21, 2005 - 11:18 AM) Its not on the retractor simply because some people are all different sizes. [right][snapback]302234[/snapback][/right] it could've been on the retractor, my corolla seatbelt light switch is on the retractor This post has been edited by K-ESD: Jun 21, 2005 - 10:38 AM -------------------- ----------------------6GC's FIRST V6----------------------
Jun 29, 2005 - 12:14 PM |
Enthusiast Joined Feb 6, '03 From huntingdon tennessee Currently Offline Reputation: 1 (100%) |
about taking the gauge pod out and pulling the bulb.... how would that be done... is there a how-to around...if not... gimme some directions plox..
Jun 29, 2005 - 5:58 PM |
Dude, it will be so much easier to jumper the wires.
Lo-Fi Version | Time is now: November 27th, 2024 - 12:51 PM |
