removing dash, removing dash for paint |
Jun 19, 2005 - 1:37 AM |
Enthusiast Joined Jul 9, '04 From Las Vegas USA Currently Offline Reputation: 14 (100%) |
Hello everybody, This is my first topic I've started (hope it's not messed up) and It's a question. I'm planning on pulling my dash to paint it, simular to Frotou's and Kristen85's(minus the fur, no offense). Any advice would be greatly appreciated. I have already removed all but the upper dash (where the airbag is located) and the steering column. I know to disconnect power for at least 90 sec before even breathing on the airbag system. I can see some exposed fastners on the dash but I dont know how the airbag is connected, so I don't want to just rip it out of place. I've looked in my Chiltons manual and it doesn't go into that area, so I thought I should ask before I start. This is the last thing I need to do before I start reassembling my gutted interior. Thanks, and love the site I haven't been a member long but I've browsed the site since near the beginning.
Jun 22, 2005 - 6:43 PM |
Enthusiast Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
i wish i could help you with taking out the dash, i never done it
but if i may suggest, you could always paint it while it's still attached, tape plastic to cover from overspray. Still need to be very careful and have good ventilation. I still agree that taking the dash out would be the better way. I guess you can take some time to find everywhere it's being held, i'm sure you can figure it out, it can't be that hard. -------------------- ----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Jun 29, 2005 - 12:53 AM |
Anybody pull the dash before?
Jun 29, 2005 - 2:25 AM |
not I, but i do know that doing what they did has to be very involved...they are both show cars, and painting an interior like that is wow
my buddy used regular paint on his interior(made for the dash) and it looked good, but it cracked and looked nowhere near as shiny as those twos for the plastic inserts i believe we have a how-to written at 6gc.net -------------------- |
Jun 29, 2005 - 8:40 AM |
i have.......
all i say is you'll need hella good luck.... you have to remove anything and everything you see start with the vents and just pop them off then center console (the entire thing) then remove steering wheel plastics, gauge cluster remove glove box start to unclip every piece of wire that you can find it goes way back there and down on the sides of the car unbolt every piece of a/c:heat duct work that you can see and after that there is still MORE that is just crazy just take your time go bolt by bolt be very gentle with the dash manuevering because it can break easily.... and don't just yank that will break things and careful not to rip wires |
Jun 29, 2005 - 2:00 PM |
I have already removed everything except the steering wheel and the upper half of the dash. pulling the vents is no problem they have been pulled and painted before. I plan on using a flexible paint and primer as suggested by frotou to avoid cracking. My main question is will the airbag system come off with the dash or does it stay mounted to the firewall? Thanks to everyone with all the replies.
Jun 29, 2005 - 2:14 PM |
airbag is mounted to both on the passengerside
you have to be very careful cause you have to go at like a million angles to get to all the bolts |
Jun 29, 2005 - 4:09 PM |
Enthusiast Joined Jan 26, '05 From Ashville, Ohio Currently Offline Reputation: 2 (100%) |
QUOTE(coldbluesteel @ Jun 19, 2005 - 1:37 AM) Hello everybody, This is my first topic I've started (hope it's not messed up) and It's a question. I'm planning on pulling my dash to paint it, simular to Frotou's and Kristen85's(minus the fur, no offense). Any advice would be greatly appreciated. I have already removed all but the upper dash (where the airbag is located) and the steering column. I know to disconnect power for at least 90 sec before even breathing on the airbag system. I can see some exposed fastners on the dash but I dont know how the airbag is connected, so I don't want to just rip it out of place. I've looked in my Chiltons manual and it doesn't go into that area, so I thought I should ask before I start. This is the last thing I need to do before I start reassembling my gutted interior. Thanks, and love the site I haven't been a member long but I've browsed the site since near the beginning. [right][snapback]301168[/snapback][/right] We just tapped my doors off and the window and carpet then painted the dash, it's ALOT easier, and saves ALOT of time. But we used real car paint so it sprayed really easy, i quess it matters what kind of paint to use, and you know you like fur fur......... |
Jun 30, 2005 - 2:35 AM |
Enthusiast Joined Sep 17, '03 From Tampa FL Currently Offline Reputation: 1 (100%) |
ive done it to my 94 celi gt that im currently working on. I took out the airbags because they were deployed and the windshield because of that. i wanted to get out all of the glass shards everywhere so I took everything apart. as you can see the pass airbag is disconnected from the frame and dash. many bolts underneath to undo. you need those special keys like for the wheel airbag to get this off. there are tons of wires to disconnect and junctions in the back too. there are plastic clips in the back of the dashthat are the last things holding it on after you unbolt. the dash is very heavy and bulky! i could barely maneuver it. the shifter got in the way. steering wheel must come off so go buy a puller for like $15 and mark a spot. it was a pain but everything went back pretty easy because i put it back in the same day and had it fresh in my mind. was about 4hrs work since i never done it b4.
This post has been edited by ArizonaRed: Jun 30, 2005 - 2:38 AM -------------------- -97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre (GOT LIFT?) |
Jun 30, 2005 - 4:12 PM |
can you pop off the passenger air-bag cover w/ battery in and no work?
i'm curious because mine has a rattle and i'd like to fix it. -------------------- |
Jun 30, 2005 - 11:46 PM |
Thanks everybody, pics were great, any more advice.
Jul 1, 2005 - 2:37 AM |
QUOTE(Consynx @ Jun 30, 2005 - 9:12 PM) can you pop off the passenger air-bag cover w/ battery in and no work? i'm curious because mine has a rattle and i'd like to fix it. [right][snapback]307039[/snapback][/right] air bag cover tears. it folds in the back but is kinda plastic bolted in the front. dont mess with it or else youll never get it back the right way. (its meant to break) lets see.... take off steering wheel take off glove box take out middle consol preferably take out seats take out ac piping remove ac/cd/vents remove inst panel remove supprt panels on both sides of windshield undo all wires from fuse box and junctions undo wires that lead to the doors airbag bolts strip easily if ur sure you undid everything the dash requires quite a pull to pop off This post has been edited by ArizonaRed: Jul 1, 2005 - 2:40 AM -------------------- -97 Celica ST
Jul 1, 2005 - 2:50 AM |
QUOTE(ArizonaRed @ Jul 1, 2005 - 12:37 AM) airbag bolts strip easily [right][snapback]307194[/snapback][/right] Very true...they're T30 Torx bolts. I stripped one on my steering wheel on my purple Celi and spent hours getting it out. -------------------- New Toyota project coming soon...
Jul 6, 2005 - 2:05 AM |
Is there a trick to getting the white wire holders on the little posts off? I got all of the bolts out, but I can't figure out how to get those off at all.
Jul 10, 2005 - 11:18 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
thats cool to see under the dash... i've always wondered what it looked like
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jul 11, 2005 - 3:14 PM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
looks like WAYYYY too much work for me
Jul 11, 2005 - 4:19 PM |
QUOTE(dustin15brown @ Jul 11, 2005 - 1:14 PM) looks like WAYYYY too much work for me [right][snapback]311231[/snapback][/right] It's actually not too much work...I think once the lower dash pieces are off there were only seven 10mm(the two airbag bolts may have been 12mm...can't remember for sure) bolts/nuts that needed to be removed. The hard part is getting the wiring off the back of the dash. -------------------- New Toyota project coming soon...
Lo-Fi Version | Time is now: November 28th, 2024 - 5:40 AM |
