> Uh-oh?
post Jun 19, 2005 - 6:28 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
Ok guys for my bday I got a Optima Yellow top among other things for my car... but I rolled my ankle and didn't drive it for 6 days and the battery was dead... nothing was on.... same thing happened again today.. any ideas?
post Jun 19, 2005 - 7:31 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
Check the alternater connections, as well as other connections you may have affected electrically.
How long did you not drive it today that it happened?
post Jun 19, 2005 - 7:38 PM
dustin15brown
Joined Aug 17, '03
it got charged last night and today i went to pick the car up again... This time was ONE day.. Could there be a continuous current I dont know about? I have a BatCap300. I don't know an enormous ammount about it, but someone please help. Thanks!!!!
post Jun 19, 2005 - 10:03 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
did you change anything else other than the battery before this started?
something must be drawing power, try disconnecting (taking fuse out) aftermarket devices you think might be drawing power. Also try to charge the battery and leave it disconnected for a day just to see if it holds power. I would start with your audio equipment then move on to other factory devices.
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jun 19, 2005 - 10:06 PM
mark_426
Joined Jan 30, '05
Look at phats thread from the other day - check alternator fuse, and they also suggested going to advance auto or the sort, and they should be able to check batt/alternator pretty quckly.
Also you can check the battery acid pH
post Jun 21, 2005 - 4:11 PM
mikew04
Joined Feb 19, '04
From austin tx
Its a dry cell, they wont be able to check the acid ph. Do what K-ESD suggested, you might be running something off your power line when you should be running it off accessory.
Why are you using a cap? That would be one of the first things i'd disconnect (and probably not put back on.)
You could also be overloading your charging system; you may need to upgrade your alternator.
post Jun 22, 2005 - 12:34 AM
dustin15brown
Joined Aug 17, '03
Where can I get an upgraded alternator?
post Jun 22, 2005 - 7:15 AM
K-ESD
Joined May 5, '05
there's a few places, one of them is mr. alternator
post Jun 23, 2005 - 12:28 AM
dustin15brown
Joined Aug 17, '03
Corolla alternator Hey will this corolla work for my celi if i get the 94-97 version, because it's a 7afe too and should bolt right up.. correct?
post Jun 23, 2005 - 2:10 AM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
try another batt. it may not be holding a charge. do this b4 buying an alternator.
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
post Jun 23, 2005 - 8:05 AM
K-ESD
Joined May 5, '05
yes, don't buy an alternator until you are 100% sure it is the alternator malfunctioning (unless of course your in the market for a High ouput alternator) and the 94-97 corolla's engine is a 4AFE wink.gif
From what you told us it sounds like you are losing power constantly when the car is off. If the engine is not running the only problem you can have with the alternator is if it's shorting out, completing the circuit and discharging your battery. Usualy when this happens something goes *pow*
Before buying anything, make sure you know exactly what the problem is.
Good luck
post Jun 23, 2005 - 10:40 AM
dustin15brown
Joined Aug 17, '03
the 1.8l corolla is a 7afe i'm pretty sure... not the 1.6
EDIT: I'm also going to get a high output alt because of the size of my system.... every time it hits had at night they go dim
This post has been edited by dustin15brown: Jun 23, 2005 - 10:42 AM
post Jun 23, 2005 - 11:23 AM
K-ESD
Joined May 5, '05
yup, ur right, sorry bout that
from 93-97, the corolla has two engine codes listed in my Haynes manual
4AFE 1.6
7AFE 1.8
It's a very good idea to invest in a high output alternator but make sure your battery is good or else you could toast ur alt. pretty quickly.
post Jun 24, 2005 - 8:36 PM
dustin15brown
Joined Aug 17, '03
battery is fine... i still think i'm drawing a power source from somewhere unknown... it's not doing it right now though so i'm ok
Lo-Fi Version Time is now: December 4th, 2024 - 4:43 PM
