Need help. squeel on start & when turning |
Jun 20, 2005 - 8:09 PM |
Enthusiast Joined May 4, '05 From western MD/NOVA Currently Offline Reputation: 2 (100%) |
yup the topic tell's it all, i washed the engin bay once. then the squeeking started. but it is only when i turn on the car, and i turn the steering wheel. that's it.
even when the the car is warm. i've used the prestone belt dressing, and it left. but this week (w/ high humidity down here in the DC area) it came back... do i need to WD-40 the bearings on the pullies? or somthing??? what can i do thnx in advanced for all of the help. -------------------- |
Jun 20, 2005 - 9:07 PM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
I believe it's your power steering....
Jun 20, 2005 - 9:09 PM |
QUOTE(dustin15brown @ Jun 20, 2005 - 10:07 PM) I believe it's your power steering.... [right][snapback]302019[/snapback][/right] going out?? should i just add some flued??? wha t do u all think??? -------------------- |
Jun 20, 2005 - 9:15 PM |
it might not be either.... mine did it for a while during the winter and it just eventually stopped... i'm not the most knowledgeable on this kinda stuff, but thats what mine was.... but check your fluids just incase
Jun 20, 2005 - 9:53 PM |
It's either your belt or your pulley more than likely your belt. Just replace it. Usually if your power steering fluid is low or pump is worn it will make a whining noise not a squeeking/squeeling noise.
-------------------- Project ST204.5 99.88946% complete... |
Jun 20, 2005 - 10:03 PM |
Enthusiast Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
There are rails to adjust those belts on. Check if they're loose, and if so, get your metric wrenches, jack it up, and go to work. Make sure you have a breaker bar/prybar, and be careful what you pull on. Don't overtension them either, it will wear the bearings unevenly and you will need new belts/bearings/pulleys, depends what goes out first.
Belt dressing will wear off, mine were so bad at times that they needed dressing on every startup/run. Also, turn off the AC/fan if it does it on startup, it may be that belt too. -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Jun 20, 2005 - 10:13 PM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
one of your belts is stretched out, eith powersteering or altenator. Change it.
Jun 21, 2005 - 7:42 AM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
mine does that in the winter time. Hasn't done its since the weathers warm.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Jun 21, 2005 - 7:56 AM |
Enthusiast Joined Dec 6, '03 From Florida Currently Offline Reputation: 0 (0%) |
Sounds like my current car, gotta love Mitsubishis...
Its most likely the belts, see if it is off the track or loose, thats what usually causes squeaking. If you do change out the belt make sure the pulleys don't have any real big chips in them because that can mess up your belt (one of mine did and it was a PITA for 2 months constantly changing the belts). Maybe its time to get some new belts? When was the last time you changed them? Mileage? |
Jun 21, 2005 - 4:03 PM |
hey!!! great input guy's thanx alot!!!
that was exactly what i was looking for.... now i just need to go over all of those points on my car.... will poast later and let u all know what i did, and what it was (if i find out,trile and error,trile and error).... This post has been edited by mandrek: Jun 21, 2005 - 4:05 PM -------------------- |
Jun 25, 2005 - 10:47 PM |
Enthusiast Joined Jan 21, '05 From NY Currently Offline Reputation: 0 (0%) |
tighten your belts that should help.
-------------------- <<AKA THA RUSSIAN>>
Jun 26, 2005 - 2:06 AM |
Enthusiast Joined Jun 20, '05 From Wichita, Kansas Currently Offline Reputation: 0 (0%) |
I had this exact problem when i first got my celica. i got rid of it by buying a new pulley (which helped a little), and by adding power steering fluid which finally got rid of it.
-------------------- owner off a 95 celica st... hoping overtime to be 1 kick ass machine =).
Upgrades (comming soon)- 3sgte engine swap - small engine tweaks here and there - new paintjob (black w/ overlay of blue pearl) possible future upgrades- gt4 hood/bumper - upgrade the 3sgte turbo. |
Lo-Fi Version | Time is now: December 1st, 2024 - 3:57 AM |
