> Adding OEM fogs to 94/95
post Jun 20, 2005 - 8:15 PM
kgr-gts
Joined May 20, '04
From Saskatoon, SK, Canada
Hey all,
Some idiot smacked my front bumper so I'm replacing it with the 96-style cover. I'm getting the fog lights as well and I'd like comments from people who have added OEM fogs to a 94/95 car. I'd like to keep it as stock as possible.
I'm assuming that only 96+ cars have the wiring and sockets already. Anyone know if this is part of the car's main wire harness or if it's an optional extra harness?
Has anyone out there added fuses/relays to the box under the hood or the kick panels? There are several unused fuse ports available. I have the 96 wiring diagram for the fog lights and would like to copy it as closely as possible. I'm going to use the factory switch with fog light control.
While I'm at it... has anyone swapped the front bumper cover from 94/95 to 96+? A few parts like the energy absorber and signals have to be changed, but I'm more concerned with mounting point differences, etc. Is it a direct swap?
-kevin
post Jun 20, 2005 - 10:07 PM
it is a direct swap for the 94-95 to the 96+ bumper. I did the swap a while back and added OEM fogs. I didn't have any fogs on my 95 (the US didn't have that option) so I wired them in myself. It is very easy and does require a relay.
where is the "factory switch with fog light control" on your car ?
post Jun 21, 2005 - 5:41 PM
kgr-gts
Joined May 20, '04
I don't have the switch yet. I'm going to buy the factory switch on the headlight stalk. I believe it's a ring like the intermittent wiper adjust on the other side.
My first thought was to wire it up like you've got it, but I figured it would be cool if I could somehow merge it with the car's fusebox / harness. Probably more trouble than it's worth.
Lo-Fi Version Time is now: November 27th, 2024 - 9:10 AM
