> headlight gaskets, how do you replace them?
post Jun 21, 2005 - 2:28 PM
Valo666
Joined May 15, '05
From Toronto
so at some point in time, my celi was repainted and when they did it, they did a really shaddy job..my bumper doesnt line up fully, missed some spots painting, bits of spatter here and there, but when they put the headlights back in, they didnt put the gaskets in properly. So now all of my gasket on my highbeams on the bottom is poped out and my low beams gaskets keep fallin out/off...so how do i get the headlight out/repair it??
post Jun 21, 2005 - 3:30 PM
lilmancelica94
Joined Oct 7, '04
From Illinois
I had the exact same problem as you and am getting desperate to know what could be done to sealing those gaps in the headlights.
post Jun 21, 2005 - 3:35 PM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
If you want them secured the proper way when they were originally installed you have to take off your bumper to access the clips that hold them onto the headlight.
You basically clip the seal between the headlight and the clip and you're all set. There's about maybe 4 or 5 of them for each light.
I wouldn't glue them...especially if you live in a state where you have winters because they can harden up and eventually peel right off.
post Jun 21, 2005 - 4:15 PM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
heh i got the same problem but thinkin of just waiting to take of my bumper off when I install factory fogs and hopefully projector wink.gif
post Jun 21, 2005 - 6:01 PM
MonsterBOX
Joined Jan 8, '05
From Alabama
where can i buy more clips
post Jun 22, 2005 - 8:37 AM
CelicaQT
Joined Sep 29, '02
QUOTE(MonsterBOX @ Jun 21, 2005 - 7:01 PM)
[right][snapback]302593[/snapback][/right]
Got to your toyota dealer. Clips shouldn't cost more than $1 each. Don't know exact cost, but just go there and check out how much they'll all cost.
Just tell them that you need the clips that attach the seal to the headlight.
post Jun 22, 2005 - 5:29 PM
Valo666
Joined May 15, '05
From Toronto
how do you take the bumper off??..like how many screws are there/how long would it take??
post Jun 23, 2005 - 2:02 AM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
3 or 4 bolts to take off from both sides and like 4 from the top. might need to take your splash gaurds off. easy stuff, took me 30 min.
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
Lo-Fi Version Time is now: November 28th, 2024 - 5:01 AM
