Engine harness Q |
Engine harness Q |
Jun 21, 2005 - 2:35 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Will a 94 wiring harness be the same as my 95 harness that is in my car now? They are both obd1 so the plugs and such should be the same correct? Just the colors of the wires are different?
Jun 21, 2005 - 2:41 PM |
just play it safe and switch over anything needed...
I dont think there was a change, but there were minor changes inside, so who knows. -------------------- |
Jun 21, 2005 - 2:53 PM |
Well the reason I'm asking is because I am sending my harness and 3s harness off to be spliced together and I can't be without my car while its being done. So I am buying another 7a harness and sending that with the 3s harness to get my wiring done.
Jun 21, 2005 - 2:54 PM |
you should be ok with it.
what are u doing to the car that u need a gt harness? -------------------- 15PSI - 30MPG - Megasquirt Tuned
that will work fine
Jun 21, 2005 - 3:00 PM |
QUOTE(lagos @ Jun 21, 2005 - 7:54 PM) you should be ok with it. what are u doing to the car that u need a gt harness? [right][snapback]302437[/snapback][/right] Nah its a 94 st harness. Cool thanks. |
Lo-Fi Version | Time is now: December 3rd, 2024 - 3:20 AM |
