Parts for MR2T, GT-Four, All-Tracs, Are they the same? |
Jun 22, 2005 - 12:56 AM |
Enthusiast Joined Feb 27, '04 From Illinois Currently Offline Reputation: 1 (100%) |
I found HKS cams on ebay for a 90-95 MR2T. Is there a difference between cams for an MR2T and an All-Trac and a GT-Four?
What about other internal motor parts for MR2Ts, All-Tracs, GT-Fours? -------------------- |
Jun 22, 2005 - 1:27 AM |
I believe all of the 2nd gen heads are pretty much the same and can interchange. The only gen heads that cannot cams, I believe, is the 1st gen and the BEAMS versions...
-------------------- "It's ok to be naked girl... I'm an artist!"
Jun 22, 2005 - 10:01 AM |
90-95 MR2T contains 2 different generations of 3sgte.
Jun 22, 2005 - 12:24 PM |
90-92 mr2s are like 90-91 alltracs
alltracs changed after a certain month in 92 and 92-93alltrac parts are like 93+mr2 parts. the ecu and wiring harness are the main changes, which includes the alternator, dist. cap, coil, plug wires, and resistor pack having differences.(this is according to someone else, so im not 100%) -------------------- |
Jun 22, 2005 - 6:18 PM |
see the feasable swaps sticky.
Jun 22, 2005 - 6:25 PM |
QUOTE(Consynx @ Jun 22, 2005 - 12:24 PM) 90-92 mr2s are like 90-91 alltracs alltracs changed after a certain month in 92 and 92-93alltrac parts are like 93+mr2 parts. the ecu and wiring harness are the main changes, which includes the alternator, dist. cap, coil, plug wires, and resistor pack having differences.(this is according to someone else, so im not 100%) [right][snapback]303026[/snapback][/right] woot! u listened when i was talking! haha -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 23, 2005 - 12:06 AM |
I'm talking specifically internal parts of the motors.. Since I'm rebuilding my entire motor, I've come across parts on ebay for an MR2T and wonder if they'll work in my motor because they are both 3SGTEs.. If that makes any sense...
Jun 23, 2005 - 7:44 AM |
Yeah they'll work as long as the same generation. Even with diff. gens some parts will be interchangable but thats a case by case basis.
This post has been edited by Supersprynt: Jun 23, 2005 - 11:53 AM -------------------- |
Jun 23, 2005 - 8:21 AM |
QUOTE(Yota @ Jun 23, 2005 - 12:06 AM) I'm talking specifically internal parts of the motors.. Since I'm rebuilding my entire motor, I've come across parts on ebay for an MR2T and wonder if they'll work in my motor because they are both 3SGTEs.. If that makes any sense... [right][snapback]303407[/snapback][/right] depends on the part. If it is the same generation and its INTERNAL, it will be the same. Some bolt on accessories are different (e.g. intercooler, alternator bracket etc). If you tell us exactly what part you are considering, you might get a little more specific feedback. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jun 23, 2005 - 5:07 PM |
I was just asking in general terms, but ok.
I'm rebuilding the motor. I buying JE Pistons, HKS Cams, Ferrea Valves, UR crank Pulley. I've seen on ebay HKS 272 cams for an MR2T (90-95). Will they work for my motor? -------------------- |
Jun 24, 2005 - 8:29 AM |
QUOTE(Yota @ Jun 23, 2005 - 5:07 PM) I was just asking in general terms, but ok. I'm rebuilding the motor. I buying JE Pistons, HKS Cams, Ferrea Valves, UR crank Pulley. I've seen on ebay HKS 272 cams for an MR2T (90-95). Will they work for my motor? [right][snapback]303700[/snapback][/right] If you have a 2nd gen motor, yes. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Lo-Fi Version | Time is now: December 2nd, 2024 - 11:17 PM |
